Clutch Engage Point Adjustment - Defender Source
Old June 7th, 2015, 03:29 PM
sp543
Shawn
Have a Tithonus truck and trying to adjust the clutch pedal throw, would like it to engage closer to the floor as the engage point is pretty far up when releasing. Took off the master cylinder cover and trying to adjust it. There are nuts on either side of the pedal connection, which way should it be moved? Towards or away from the cylinder? Im thinking that the rod should be made longer, there for moving it away, but when I tried searching it came up with conflicting info and no real answer.
Old June 7th, 2015, 03:57 PM
There is no adjustment for engagement point. The master should be adjusted for the correct free play and pedal height. Download and read the workshop manual. It is clearly explained there. If you add in a bunch of extra freeplay to get a lower engagement point, things end up too lose and something can come apart.
Old June 7th, 2015, 06:22 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
so̝u̝n̝d̝ l̝i̝k̝e̝ c̝l̝u̝t̝c̝h̝ t̝i̝m̝e̝ t̝o̝ m̝e̝
No Mall crawler here
Old June 7th, 2015, 06:44 PM
sp543
Shawn
Has never slipped and has strong engage point, its just higher in the pedal throw than I would like/I am used to. Guess its just something Ill have to get used to.
Old June 7th, 2015, 06:48 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
Make sure there's some play in the pedal. ..see work shop manual
Also in 5th gear if you rest your foot on the pedal while at speed and if disengages or slips it's a strong sign of a worn friction plate. I just went though this with my 130
Old June 7th, 2015, 06:49 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Just adjust Pedal closer to the floor when static
Legend in My Own Mind.
Old June 7th, 2015, 06:54 PM
Hydraulic system takes up wear naturally. When the release/pick up point runs out of travel it's time for a new clutch.
clutch
Point to point camping? Tennessee to Maine. Brentflyfish Trips, Trails and Events 10 May 13th, 2015 11:58 AM
Engage clutch - shudder and clunk Ghale Defender Technical Discussions 4 August 16th, 2013 04:16 PM
Clutch does not engage - do I need to bleed? sro Defender Technical Discussions 18 January 2nd, 2013 11:28 PM
Clutch will not engage fully Hbmike Defender Technical Discussions 1 December 27th, 2012 10:07 PM
is there a clutch pedal adjustment for 95 d 90? rickauf Defender Technical Discussions 6 May 21st, 2008 02:56 PM
