clutch drain plug? - Defender Source
Join the Defender Source Community Today
Old October 1st, 2016, 02:44 PM
jackstraw
geoff vezzetti
1998 d 110
clutch drain plug?
I just replace the slave on my 1988 d 110 rt77
As I refilled the master cylinder and started the bleeding process I noticed the clutch pedal was not building up pressure. I noticed then that fluid was now leaking out the bottom of the clutch housing. (see pic) I hope this is a drain of some sort for the clutch. I did not notice this before or remove it. What is this? This could be the source of my initial problem?
any ideas fellas?
Old October 1st, 2016, 02:52 PM
Its the hole where you are meant to put a wading plug in to protect the clutch from water.
https://www.google.com/url?sa=i&rct=...75434346195682
Old October 1st, 2016, 02:55 PM
jackstraw
geoff vezzetti
1998 d 110
thanks Rocky?
I need one for the clutch to pressure up properly?
Do you happen to know thread and pitch?
this is essential?
wondering where mine is and why its missing.
thanks man!
Old October 1st, 2016, 03:07 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
if you have fluid coming out your slave is nackered, just don't think putting a plug in will help you.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 FHC
Old October 1st, 2016, 04:43 PM
jackstraw
geoff vezzetti
1998 d 110
And now I know what nackard is, I told my mechanic and he got a good laugh! Sill laughing!
that being said I removed the slave,, rest the piston and re installed .. It working fine now!
Thanks for the lesson in vernacular .. Or should i say VernNACKular.
Cheers!
Geoff
Old October 1st, 2016, 05:05 PM
Should replace them in pairs anyways.
Old October 1st, 2016, 07:12 PM
Originally Posted by jackstraw View Post
thanks Rocky?
this is essential?
thanks man!
The wading plug hole is meant to be open unless you put a wading plug in.
That way you know when your clutch fluid is leaking out.
clutch, drain, drain plug
Transfer Case Drain Plug Problem kzack Defender Technical Discussions 10 October 21st, 2010 08:14 AM
Wading plug and drain hole? T.U. Defender Technical Discussions 4 April 6th, 2010 03:48 PM
Drain Plug Diffs/Xfer Case Grover Defender Technical Discussions 7 November 11th, 2009 11:21 PM
where is drain plug for the swivel housing UpnOver Defender Technical Discussions 10 July 23rd, 2007 03:23 PM
Oil pan drain plug thread Pat Defender Technical Discussions 0 June 23rd, 2006 09:02 AM
