Clutch Died - Defender Source
Old July 29th, 2009, 06:56 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
Clutch Died
D-90, 200Tdi, LT77/LT230. I was driving along happily, and suddenly I couldn't select gears. Pedal feels normal, so I don't think it's a hydraulic problem (BTDT). I didn't hear any expensive noises, just lost the ability to select gears. I can stop the engine, select a gear, start and drive, but I can't select gears without declutching, as I did when the hydraulics died, but that was with another gearbox. I can come to a stop in gear, but the clutch doesn't release completely.
Looking for a diagnosis.
John Karlsson
Hope Valley, RI
Old July 29th, 2009, 08:43 PM
Probably broke the release fork thing.
Old July 29th, 2009, 08:47 PM
Can select any and all gears when stopped?
Old July 29th, 2009, 09:22 PM
John_Karlsson
John Karlsson
I didn't try every gear, but the ones I tried all worked, so I don't think it is a gearbox problem.
John Karlsson
Hope Valley, RI
Old August 3rd, 2009, 01:07 PM
John_Karlsson
John Karlsson
I just got a call from the local mechanic, who probably has never worked on a Defender before. He agrees that the problem is probably the release fork, but he wants to know the best way to get to it. Does he need to pull the engine, transmission, or both?
John Karlsson
Hope Valley, RI
Old August 3rd, 2009, 01:13 PM
Either engine or transmission, but I have not done it myself on a 200tdi so I don't know what is easier or if there is another way. Personally, I would pull the motor, but that is just me.
Old August 14th, 2009, 03:49 PM
John_Karlsson
John Karlsson
Is there a common (in the USA) pilot shaft that would fit the 200 Tdi/LT77?
John Karlsson
Hope Valley, RI
Old August 14th, 2009, 04:28 PM
What is a pilot shaft? What is broken exactly?
Old August 14th, 2009, 05:08 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
It could be the little plastic clip that connects the clutch slave cylinder to the fork. Pull the slave cylinder and look in with a light (and mirror) to see if the clip is still on the fork.
Old August 14th, 2009, 06:22 PM
John_Karlsson
John Karlsson
Pilot shaft=clutch alignment shaft. I ran into the mechanic today, and he was talking about making a shaft. If I could tell him a common equivalent, he would probably already have one on hand.
I stopped by to have a look after he got the transmission moved back. The release fork is in good shape and had been heavily reinforced. The diaphragm spring on the pressure plate looks flat, not raised, but he hasn't yet removed it to see what's wrong. All parts are in hand so it's just a matter of repairing the US Mail truck that bumped me down on the priority list.
John Karlsson
Hope Valley, RI
Old August 24th, 2009, 06:35 PM
John_Karlsson
John Karlsson
Just got the Rover back. I was pretty sure it was going to be the release fork, but it turned out to be the clutch disc. The lining was in great shape and firmly attached, but one of the rivets that hold the metal "sandwich" together had apparently come loose, so the sandwich started to separate, and the little coil springs were flopping around. The shop owner said he had never seen one do that before.
John Karlsson
Hope Valley, RI
clutch
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
