Clutch Diagnosis - Defender Source
Old August 15th, 2011, 06:41 PM
dfscott
Daryl Scott
1994 Defender
Clutch Diagnosis
How might I go about fixing the problem I describe below?
  • my clutch was slow to return to the upright position.
  • and It progressively worsened
  • and then I couldn't select a gear
  • so I added brake fluid
  • and this helped
  • yet the clutch still misbehaves
  • sometimes it doesn't return to upright
  • and sometimes I can't select a gear
  • but pumping the clutch in neutral helps
  • and I see no evidence of a leak.
thanks.
Daryl Scott
Old August 15th, 2011, 06:48 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
If you added fluid...then there is a leak! It's a closed system which means the fluid has to go somewhere. Take a good look @ the slave cylinder and even unbolt it and see if you're leaking into the bell housing.
Old August 15th, 2011, 07:02 PM
Replace flexline on bulkhead MC and slave. How many miles on your truck?
Old August 17th, 2011, 06:27 PM
dfscott
Daryl Scott
1994 Defender
90,000 miles
Old September 5th, 2011, 09:35 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
Originally Posted by dfscott View Post
90,000 miles
As was previously suggested, definitely check the flex line between the bulkhead and the slave cylinder at the transmission bell housing.
Also, with that many miles, it might be time for a slave cylinder or master cylinder... or both. My master went out with ~50,000 miles and the slave went out with about 90,000 miles.
clutch
clutch problem diagnosis help... bharris Defender Technical Discussions 18 November 14th, 2011 04:42 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
