Clutch clicking - Defender Source
Old August 16th, 2014, 01:14 PM
bjf's Avatar
bjf
barry f
94 ST #395
Clutch clicking
My truck shifts fine and the clutch is fairly new but lately I have developed this clicking when I am taking my foot off the pedal. It seems the pedal has a tiny bit of play but so does the brake and gas. Any idea? It's inly when I am taking my foot totally off.
Old August 16th, 2014, 05:06 PM
bjf's Avatar
bjf
barry f
94 ST #395
Pedal area
Old August 16th, 2014, 05:40 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Just lubricate this area:
Old August 16th, 2014, 06:07 PM
bjf's Avatar
bjf
barry f
94 ST #395
Will check it out
------ Follow up post added August 16th, 2014 03:08 PM ------
Can I adjust the slack nut?
Old August 16th, 2014, 06:21 PM
bjf's Avatar
bjf
barry f
94 ST #395
Why don't you just tell me
------ Follow up post added August 16th, 2014 03:22 PM ------
Is it hard?
Old August 16th, 2014, 06:37 PM
bjf's Avatar
bjf
barry f
94 ST #395
Why would this just come out adjustment? I'm too lazy to look it up or go outside and check
Old August 16th, 2014, 06:43 PM
the nuts do tend to "back off" over time, i've seen it happen twice (after all they are just 2 nuts tightened to each other). the truck is, you need a "half wrench" (13mm) to get into the area properly and tighten. I cut a cheapie in half and keep it in my under-seat Garrison case.
Old August 16th, 2014, 06:45 PM
bjf's Avatar
bjf
barry f
94 ST #395
Ah I will look. Just too lazy to put on my shoes.
So when this nut backs off you get a but of play at the top of the pedal? Clutch engages properly etc.
Old August 16th, 2014, 06:50 PM
Yes, essentially there is a nut on the backside (towards the grill) that stays stationary, the "double-nut" is towards the firewall side...if they back off you'll get a little more play (since the rod now has more room to move between the front & back nuts). Now, there actually *should* be a little bit of freeplay actually built in (maybe a 1/4" or so, it state so in the manual as Jeff mentioned)....just don't snug them up tight thinking that's how it should be.
Old August 16th, 2014, 07:14 PM
bjf's Avatar
bjf
barry f
94 ST #395
Couldn't find a thread on it. Where is horsey
Old August 16th, 2014, 08:13 PM
For my lazy fellow Israelite:
Drive your truck to Phoenix and I'll adjust it for you right in my driveway.
Old August 16th, 2014, 08:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by javelinadave View Post
For my lazy fellow Israelite: Drive your truck to Phoenix and I'll adjust it for you right in my driveway.
I will take a look to see if that's it. Don't feel like screwing it up obviously
Old January 14th, 2015, 02:28 PM
bjf's Avatar
bjf
barry f
94 ST #395
Bringing this back up. The clicking in my pedal is intermittent. My truck is in the shop for new belts and I asked the mechanic to fix it. He thinks it is a bushing in the pedal assembly. Is there such a bushing? I want to steer him in the right direction like a arm chair quarterback. It only happens when you take your foot fully off clutch or just press it slightly.
Thoughts?
Old January 14th, 2015, 02:35 PM
http://www.allbrit.de/UNI.cfm?PAGE=757393&SPRACHE=EN
Old January 14th, 2015, 02:38 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Thoughts?
Did you message half shirt?
Old January 14th, 2015, 02:51 PM
bjf's Avatar
bjf
barry f
94 ST #395
I did message half shirt but this might be one of the rare times he isn't either on the board or on his computer.
Old January 17th, 2015, 11:14 AM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
It maybe the rubber boot on the clutch adjustment piston rod. White grease fixed it for me.
Old January 17th, 2015, 08:01 PM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks. I will check. My shop said they fixed it by removing play at the pedal. I got in the truck and it made noise. Only difference now is the pedal doesn't have a slight bit of play if you just touch it. Problem is I think it should have that play. Right now I have rage. Love my shop but nothing I hate more than being told something is fixed and having to go back. I only took it because I had to leave my lr4 because the thing has a vibration after they did control arm bushings.
Ready to ditch this shit and get a porsche
Old January 18th, 2015, 09:39 AM
Barry,
If you feel any slipping at all stop driving. The free play in the pedal is critical and if pressure builds up the clutch slips it will burn up.
Old January 18th, 2015, 09:52 AM
bjf's Avatar
bjf
barry f
94 ST #395
It actually felt like it was slipping in third. Just felt weird. Truck is going back to the shop this week. For now it is just sitting.
Clutch clicking at top of travel bjf Defender Technical Discussions 3 February 22nd, 2011 09:39 PM
turn signal clicking Caribsurf Defender Technical Discussions 5 October 31st, 2006 04:17 PM
Clicking noise from behind IP - 97 D90 Saito Defender Technical Discussions 3 March 28th, 2006 11:17 AM
Transmission clicking? oldscratchggf Defender Technical Discussions 1 June 14th, 2005 06:42 AM
Clicking from the dash? greg_sikes Defender Technical Discussions 14 November 9th, 2003 07:31 PM
» Defender Registry
90 V8
KeithD
mannarosa
motard
Add your Defender
