Clutch clicking - Page 2 - Defender Source
Old January 18th, 2015, 09:58 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Originally Posted by evilfij View Post
Barry, If you feel any slipping at all stop driving. The free play in the pedal is critical and if pressure builds up the clutch slips it will burn up.
And burn out the throw-out bearing.
Old January 18th, 2015, 10:12 AM
bjf's Avatar
bjf
barry f
94 ST #395
You can't believe my rage level. I gave my mechanic the attached image and yet he just decided to remove the free play entirely.
Old January 18th, 2015, 05:07 PM
Roover's Avatar
Roover
Mat Morgan
94 defender 90
Originally Posted by Roover View Post
It maybe the rubber boot on the clutch adjustment piston rod. White grease fixed it for me.
the push rod gets chewed up during past adjustments, the rubber boot catches on the rod and makes a clicking/ poping sound.
Old January 23rd, 2015, 08:01 PM
bjf's Avatar
bjf
barry f
94 ST #395
Noticed in my truck the brake lines run right over the clutch box. Doesn't that make it beyond annoying to adjust free play?
Old January 23rd, 2015, 08:04 PM
Did this last night. But yes. I also have some other cable in there which I moved out of the way. You can probably bend the brake lines back under the wing a little more without consequence.
Also helps immensely if you spend 2 minutes and make one of these:
Old January 23rd, 2015, 08:36 PM
bjf's Avatar
bjf
barry f
94 ST #395
Will make one of those wrenches by breaking it with my bare hands.
Old January 23rd, 2015, 08:37 PM
Out of Rover-rage I'm assuming?
Old January 23rd, 2015, 08:42 PM
Can you hammer a six-inch spike through a board with your penis?
-Jeff
Should I call you Nick, or "Mr. Dick"?
bjf's Avatar
bjf
barry f
94 ST #395
-Jeff
Going to hate fuck the clutch.
Old January 23rd, 2015, 08:57 PM
-Jeff
Briggs,
You are the Charles Barkley of Defender Source!
New signature line for me. Thanks!
Old January 23rd, 2015, 09:00 PM
cbfritz_03
Carmen
none
I want to use 'hate fuck the clutch'...that's some funny sh*t lol
Old January 25th, 2015, 11:12 PM
bjf's Avatar
bjf
barry f
94 ST #395
Out of my fucking mind.
Take kick panel off in the truck. Open hood, remove six screws to clutch cover. Try to get my fat fingers in there to loosen the two nuts. Cant do it. Call Lavender. Complain. Use a dremel to cut a wrench in half. Still barely can get in there. Finally loosen the nyloc nut some how. More rage. Call the shop that fucked with clutch. "Oh we didn't open the cover, we just screwed with the pedal height adjustment screw.
Brain explodes.
I readjsut pedal height based on manual. Tighten nylon washer. Need to drive without my kick panel and see if the clicking is gone.
If so I might have to return all the bushings and crap I bought at RN.
Old January 26th, 2015, 12:01 AM
bjf's Avatar
bjf
barry f
94 ST #395
No chance horsey could get his hoof in there.
Old January 26th, 2015, 07:54 AM
I hope you have found a new shop to take your truck to!
Originally Posted by pendy
I'm here for the D's
Clutch clicking at top of travel bjf Defender Technical Discussions 3 February 22nd, 2011 09:39 PM
turn signal clicking Caribsurf Defender Technical Discussions 5 October 31st, 2006 04:17 PM
Clicking noise from behind IP - 97 D90 Saito Defender Technical Discussions 3 March 28th, 2006 11:17 AM
Transmission clicking? oldscratchggf Defender Technical Discussions 1 June 14th, 2005 06:42 AM
Clicking from the dash? greg_sikes Defender Technical Discussions 14 November 9th, 2003 07:31 PM
