clutch changing? - Page 2 - Defender Source
Old January 23rd, 2012, 07:55 AM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
ok i will look into a pressure bleeder thanks guy it will be going to the mechanic today. because i have to get it back on the road asap. i'll make sure to tell him all this.
Old January 23rd, 2012, 12:11 PM
edh
Ex mod 90
I have a leak in the clutch hydraulics of my ex-MoD too. My truck is leaking fluid though, it started happening when temps got below freezing, which just recently occured. So I am assuming it is the seals on the master or slave. I don't see an obvious leak, is there an easy way to identify which is the culprit? And is it an easy job to rebuild either if serviceable, or is it better to replace w/ new o.e.? I have limited time and $ due to a home reno project, so any advice is welcome.
clutch
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
