Clutch change, advices/tricks/warnings ? - Defender Source
Old January 11th, 2010, 04:31 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'm doing it this week, i'm planning to change clutch cover,
clutch plate and release bearing.
As i'll have access, i'll also change rear main seal.
Any good advice or warning ?
Just in case someone wants to know, part numbers are:
cover URB100760 / plate UQB500030 / bearing FTC5200
rear seal LUF100430 / gasket ERR6811
- Charles Eames
Old January 11th, 2010, 04:48 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
be prepared to pull the flywheel too, often need resurfacing. Get an alignment pilot tool if you can find one at a fair price, very helpful for making a quick install.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 11th, 2010, 04:49 PM
don't forget to remove the half round shaped cover plate on the bottom of the transmission.
Old January 11th, 2010, 05:08 PM
what about the cross seals on the rear main cap and might as well do the slave cylinder and flex hose.
Old January 11th, 2010, 05:41 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Hans, thanks.
Ron, whaat ?
Phillip, I'm doing the slave also, the flex looks still
really well but i'll check it closely. Where are those cross
seals ?
- Charles Eames
Old January 11th, 2010, 06:53 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
+1 on that clutch alignment tool. Or get an old main shaft and use that (providing that the teeth aren't sheared off).
Robert Deniro
Old January 11th, 2010, 07:11 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
And the bushing in the flywheel.
Are you planning to drop the transmission or just pull it back?
John Karlsson
Hope Valley, RI
Old January 11th, 2010, 09:10 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'll drop it. I may also change rear propshaft u-joints.
- Charles Eames
Old January 11th, 2010, 10:01 PM
huck1974's Avatar
huck1974
shane cates
94 d90
the plastic clutch alignment tool at the auto parts store that fits Mitsubishi fits.
Always do the rear main and resurface flywheel. Use small sections of 2x4 against the frame with a bottle jack and a piece of pipe to get the crossmember out of the way.
Reach way up high on top of the transfer case to make sure you pulled those two wires. Mark them so you remember where they go so that your diff lock light works again.
I have a lift and a tranny jack. Hope you have both or a good friend with both. It sucks even with them. You couldnt pay me to do it without them.
Don't force things on the way back in or you will end up starting over.
Good luck, been there twice recently
And hay
And I love you too
Old January 12th, 2010, 10:23 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Make the jack adaptor.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 12th, 2010, 11:03 AM
When I pulled my first trans, I forgot to take over the cover plate on the bottom part of the front of the bellhousing. as a result I thought it was stuck, but it was the clutch hitting the plate.
Old January 12th, 2010, 11:39 AM
Must be a V8 thing
Old January 12th, 2010, 11:46 AM
Also replace the clutch fork and slippers. These wear.
Old January 12th, 2010, 12:57 PM
Neil McCauley
Neil McCauley
[QUOTE=
Good luck, been there twice recently[/QUOTE]
Just curious, what do you mean when you say starting over, like if the release bearing was to accidentally get unpinned while fitting?
Robert Deniro
Old January 12th, 2010, 01:01 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Oh, two things I forgot.
- Make some locating dowels. Bell housing to flywheel housing size bolts (3/8 x 16tpi) about 4-6" long with the heads cut off and slightly tapered. 4 should be enough. Screw them in to the flywheel housing and use as guides to fit the gearbox.
- When refitting be careful not to catch the O2 sensor leads inside the bell housing. Don't ask me how I know what a pain it is.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 13th, 2010, 07:21 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Thanks for all inputs, probably starting tomorrow.
- Charles Eames
Old January 13th, 2010, 09:13 PM
huck1974's Avatar
huck1974
shane cates
94 d90
If you get pissed off at it you can easily F up the pilot bushing.
And hay
And I love you too
Old January 14th, 2010, 12:11 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Transmision out this morning. The fault was on the clutch
release arm. Popped open on the lever point, i guess
lack of lubrication weared and weakened it.
I'll change disk and plate anyway as i'm there now.
- Charles Eames
Old January 20th, 2010, 05:36 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
A few pics better than a thousand words, also the
trans. before and after:
Name:	Clutch fork 1.jpg
ID:	24579   Click image for larger version
Name:	Clutch fork 2.jpg
ID:	24581   Click image for larger version
- Charles Eames
Old January 20th, 2010, 05:55 PM
John_Karlsson
John Karlsson
That's a known weak point. Look here for a cure:
http://www.britrest.com/Projects/dis...ine_swap_3.htm
John Karlsson
Hope Valley, RI
clutch
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
