Clutch change, advices/tricks/warnings ? - Page 2 - Defender Source
Old January 20th, 2010, 08:27 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
There should be a post for the little things not forget when doing major jobs!
I just found out about the soft clutch line the hard way(that was the one thing I didn't change with the master and slave)
And now I'm worried I didn't change the clutch fork and slippers!
Old January 21st, 2010, 09:23 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
a good tip for the clutch fork is to replace the fork and pivot with the cast type used on early V8's they dont snap on the arms or wear through the pivot.
you can also buy a modified arm that has a tab welded across the back of the arm over the pivot socket
you should look at the pivot in the belhousing, make sure it has not worn a shoulder into it off the pivot as the will shag a new arm pronto.
regards.
Old January 21st, 2010, 09:55 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Better safe than sorry so i'll change the pivot also and weld
reinforcement on the arm.
Damned, before you know the all clutch is new !
- Charles Eames
Old January 21st, 2010, 11:22 AM
I was wondering what would cause you to need a clutch that soon.
clutch
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
