Clutch bleeding woes - Defender Source
Old August 31st, 2011, 07:14 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I've bleed the clutch about 50 times, I finally got really good a couple times today, the problem is every time I shut the truck off it stops working and I have to bleed it again.
I even drove it 3-4 miles(stop and go traffic) and it worked great, as soon as I shut it off and started it again it wouldn't go into gear.
Everything is new except the hard lines which are about 2 years old.
Old August 31st, 2011, 07:25 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Any loss of fluid?
It sounds like the slave might be leaking air from somewhere.
Old August 31st, 2011, 07:31 PM
s3landy
Mike Wallace
I always had trouble bleeding the clutch on my Series 3. This time on my Defender I parked the front end of the truck on a 4 foot bank and then bled the system. It worked like a dream, first time. The slave is on a downward angle otherwise and can be a royal pain.
Old August 31st, 2011, 07:33 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
No leaks that I can see.
Old August 31st, 2011, 07:54 PM
how is the pedal free play?
Old August 31st, 2011, 08:16 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Pedal feels good, not sure what you mean as far as free play?
Old September 1st, 2011, 08:28 AM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
I use a big, 30CC syringe and some acuarium air hose to inject fluid into the slave cylinder's niple. When you see no more bubbles in the reservoir, you have a totaly bled system.
Total time, about 5 minutes.
Old September 1st, 2011, 09:32 AM
Naplm00
Matthew
Want to borrow my power bleeder? It is a pressure assisted bleeder, for really troublesome cars to bleed like my wifes Landcruiser with a variable rear proportioning valve I will roll the truck onot ramps int he front and rear while in the process of bleeding. This always works..makes it a one man job too
Old September 1st, 2011, 11:39 AM
reb78
REB
Land Rover 110
Is the slave fitted the right way up (bleed nipple to the top)? If its upside down, it wont bleed properly. I only mention it as it seems a common mistake.
Old September 1st, 2011, 03:41 PM
x2 check this first
Old September 1st, 2011, 04:57 PM
T1G UP's Avatar
T1G UP
marcus
Puma 110 xs. Td5 110 xs for sale
do you lose the pedal every now and again?
if you hold the clutch down dos it eventually start to bite?
My 90 use to do this, the seal must f flippped over when i chsnged the fliud and would go then be ok for months
2011. 110 XS SW. 1999 TD5 110 XS SW Project For sale
Old September 1st, 2011, 05:07 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
The slave is in right.
Marcus, what seal was flipped?
I borrowed a jack from work, I'm going to raise the front end and try and bleed it again tonight.
thanks fro the ideas
Old September 1st, 2011, 06:03 PM
reb78
REB
Land Rover 110
Have you tried a pressure bleeder like the gunson eezi bleed? Reverse bleeding it is also a good idea - i've never needed to do it this way but have heard it described various ways - one was just using an oil can.
What bits have you replaced in the system? Could be a failing slave or master.
Old September 1st, 2011, 07:10 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Everything but the hard lines are new, but I think I may of found the problem.
The soft line was pulled pretty tight and I an wondering if something wasn't pinched or pulled out of shape.
Old September 5th, 2011, 09:18 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
I've used this on my 1984 Mercedes 190D and it worked like a charm.
I've had bad luck with power bleeders on Defenders because of the way the reservoir connects to the master cylinder... the rubber grommets don't provide a very tight seal and as soon as I put ~5psi on the reservoir with the power bleeder, brake fluid leaks out from around the grommets, even with new grommets. Power bleeders are great for other cars, and I love mine, I'm just saying to be careful if/when you use it on the D90
Originally Posted by evilfij View Post
x2 check this first
x3 on checking the position of the slave, although it sounds like you've already checked that.
Sounds like that might be it, hopefully it'll bleed right after you unkink that hose. Good luck.
Old September 16th, 2011, 09:34 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Well, the lack of clutch has been figured out. One on the springs on the pressure plate went, I was able to see pieces through the wading hole.
I can't figure out if this was the original problem or if the spring broke do to all the pumping I was doing on the clutch trying to bleed.
The one drive I took when it briefly bleed was fine, no grinding or noise.
Anyone have an idea why the spring would break after only 20k?
Old September 17th, 2011, 08:47 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Britpart?
Land Rover 110
Old September 17th, 2011, 10:48 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I don't remember where I got it. Looking into it.
bleed, clutch
Slave clutch bleeding nikojo Defender Technical Discussions 12 April 26th, 2011 02:39 PM
Clutch woes... Trigger Defender Technical Discussions 8 September 9th, 2010 07:01 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
