clutch bearly engaging! - Defender Source
Old January 14th, 2015, 02:26 PM
4x4Canada
a
1994 Defender 110 300tdi
about mid way through a 5000mile road trip over summer the clutch began to get some play, at the end of the road trip it was taken to the shop and the slave cylinder(I think) was put in upside down. so two months ago the clutch only had about an inch at the end of the pedal where it was actually doing anything, so it was brought to the shop and they adjusted something (I forget what it was exactly) and that just raised the inch of the pedal where it was actually doing anything to the top of the pedal. so instead having to push the pedal all the way to the floor to put it in gear, you would only have to push it down the first inch, and then the rest pedal did nothing. so after it was adjusted, it had to driven on a 200mi trip. the bite point kept on getting lower and lower on the trip until it was down to the bottom of the pedal again, then that inch of the pedal that actually did something turned into half an inch. so you can get it going, but you have build up the revs and then it jerks forwards the millisecond you begin to let off the clutch. the clutch was replaced last spring and has less than 10,000 mi's on it. the only mechanic the knows anything about defenders is an hours drive, and I don't think it'll make it there. any possible resolutions to this problem would be really appreciated.
Old January 14th, 2015, 02:28 PM
87 D110 (Ruby)
maybe it needs the "bear necessities" baaaahaaaa Sorry, couldn't help myself...just yuking.
Does sound like a slave cylinder leak/issue - replace that first, then go back to lines. Assuming you have bled that and the bleeder valve is tightly on....any fluid leaks? Fluid topped off?
Old January 14th, 2015, 02:30 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Hahahahahahahaha!
That there is funny...
Attributed to Shayne...
Old January 14th, 2015, 02:33 PM
Hydraulic clutches go that way when the clutch itself is worn out. Yet yours is apparently new.....
Is the fluid level dropping?
I couldn't BEAR the thought that you have to pull the clutch out again.
Old January 14th, 2015, 02:36 PM
Go through the steps in the workshop manual to adjust the pedal height and free play first and then see where things are at.
Old January 14th, 2015, 02:41 PM
Here you go.
Old January 14th, 2015, 02:45 PM
Where are you located? What shop did you use?
Old January 14th, 2015, 02:46 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
I had a very similar situation recently with my truck - the clutch only worked in the first 1/4 of the pedal travel up from the floor. I did not replace the slave cylinder when I rebuilt the engine and trans and it started leaking. Since the nose of it is in the bell housing, the leak runs out the vent/drain on the bottom of the bell housing so the slave cylinder looks okay on the outside. Not a hard fix, so take a look at that first.
Angus
Old January 14th, 2015, 03:48 PM
jruti's Avatar
jruti
Jon Ruti
'94 D-90, #20
I had same problem and this was the same solution. Quick fix.
Old January 14th, 2015, 05:17 PM
4x4Canada
a
haha I had to wright this whole thing up in about a minute and didn't even have time to check for mistakes so please forgive my misspellings
Old January 15th, 2015, 12:22 PM
4x4Canada
a
the fluid drops a little after a lot of city driving
clutch
LT230 shifter not engaging Abrooks Defender Technical Discussions 3 March 13th, 2013 10:05 PM
AC clutch not engaging (94 D-90) down_shift Defender Technical Discussions 16 August 25th, 2012 04:27 AM
clutch not engaging properly FlaD90 Defender Technical Discussions 18 December 19th, 2009 03:46 PM
Engaging low ? mlw911 Defender Technical Discussions 6 June 15th, 2006 09:55 PM
Lurchy clutch Seanh Defender Technical Discussions 4 December 18th, 2003 11:30 AM
