Clutch and slave - Defender Source
Old June 19th, 2016, 02:25 PM
bcourtney's Avatar
bcourtney
Robert Courtney
1973 Series III 200TDI
Clutch and slave
I just completed a 300 TDI and R380 conversion and I cannot get the clutch to work properly. From what I can read the correct slave should be ftc 5072 and push rod should be ftc 3912 based on it being an earlier batch of the R380. I have gone back and forth between the 5072 and what I believe to be a 5202. I have the 5199 push rod but add and subtracted length trying to find some combo that woks. Problem I am having is either the clutch won't disengage or it slips. I cannot find any point in between. I have made adjustments to the pedal box as well. Driving me insane, anyone have any input please?
Old June 19th, 2016, 03:03 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
What clutch release bearing did you put in? There is a short and long one. Perhaps causing a problem?
Old June 19th, 2016, 03:05 PM
Bob:
Small point, but make sure the bleed nipple on the SC is "up"....can't tell you how many times I've seen it the other way, which obviously would cause the system to not bleed properly and would/could cause spotty clutch issues.
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
There's no way the friction plate could be in backwards? Ask me how I know about that problem.... With a standard setup that would prevent disengagement.
Old June 19th, 2016, 04:36 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Sounds like a bad slave, or free play adjustment
Old June 24th, 2016, 07:18 AM
bcourtney's Avatar
bcourtney
Robert Courtney
So update on this. I replaced the master and slave so they are matched. I have the correct push rod that fits in without putting pre load on fork. I also used a flexible camera and scoped around inside the bell housing and everything on the inside is in order. I have adjusted pedal out as far as it will go on the master. Bleed screw is in the up position. I have a completely firm pedal but clutch still will not disengage. At a total loss here.
Old June 24th, 2016, 10:11 AM
Clutch in backwards or wrong throwout bearing?
Old June 24th, 2016, 10:17 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Contact lav he will walk you through adjusting the free play adjustment...
clutch, slave
200tdi LT77 Clutch MC and Slave? BlackField Defender Technical Discussions 12 February 25th, 2016 07:11 AM
FS: Clutch master and slave ECR For Sale - Parts 0 January 24th, 2014 12:11 PM
LT77S Transmission and Clutch slave leak Mpfish82 Defender Technical Discussions 7 September 11th, 2013 01:48 PM
Sleeving Clutch Master and Slave nikojo Defender Technical Discussions 3 March 22nd, 2011 03:43 AM
Clutch master and slave huck1974 Misc. Chit-Chat 7 February 2nd, 2010 10:14 AM
