clutch alignment tool - Defender Source
Old November 7th, 2011, 11:30 AM
Naplm00
Matthew
Ive read on there that a mitsu one will work. Any more specifics on this? I want to go buy one before i delve into my engine swap
Old November 7th, 2011, 12:08 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
The universal KD or Lisle ones work fine. I can't remember if I use the metric or SAE one.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 7th, 2011, 12:14 PM
My clutch came with one.
Ron
Old November 7th, 2011, 12:15 PM
I bought one from RN and it was too small for 3.9 V8. I ended up taking a socket extension and wound masking tape on two points until it was the right outer diameter at the tip and the splined point and used that. Worked fine.
Originally Posted by pendy
I'm here for the D's
Old November 7th, 2011, 01:53 PM
You can buy correct plastic ones for most vehicles for around $10.
http://www.clutchtools.com/index.php?categoryID=1291
Old November 7th, 2011, 01:56 PM
Naplm00
Matthew
:-c no tdi
Old November 7th, 2011, 06:49 PM
Originally Posted by Naplm00 View Post
:-c no tdi
63 fits, same as all Rover based engines from Series 2 on.
2.25P, 2.25D. 2.5D, 2.5TD, 200TDI, 300TDI all have the same clutch pattern.
Old November 7th, 2011, 07:11 PM
Naplm00
Matthew
Thank you sir
alignment, clutch
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
