Clutch adjustment question - Defender Source
Old August 20th, 2010, 02:53 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
OK, so all of a sudden I notice my clutch is engaging very close to the floor when I release the pedal & there is a bit of loose play when I depress the pedal. Any idea if it is an adjustment & if so, how do I do it?
Old August 20th, 2010, 05:16 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
You can adjust how the pedal will move the master cilinder, not a lot but you can give or take a little bit on pedal course.
- Charles Eames
Old August 20th, 2010, 06:37 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I'd bleed it.
Old August 20th, 2010, 11:13 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Steve is right, first thing first, bleed it and put some new dot4 fluid.
- Charles Eames
Old August 21st, 2010, 12:06 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Also, note the colour of the fluid you bleed out. It should be yellowish, if it has gone black that is a sign that seals somwhere in either the master or slave (likely the slave, they get pretty hot in their location and tend to fail quite often) are degrading. If after putting in fresh fluid it goes black again in a short period of time it is a sign you may want to have a spare on hand.
Old August 21st, 2010, 01:19 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
OK, here's a silly question- how do you bleed it?
clutch
Yes, It's another overheating/Fan clutch question bd90 Defender Technical Discussions 11 September 5th, 2009 09:45 PM
is there a clutch pedal adjustment for 95 d 90? rickauf Defender Technical Discussions 6 May 21st, 2008 02:56 PM
'94 clutch and transmission question CDN38 Defender Technical Discussions 4 January 31st, 2006 01:32 PM
Latest question. Thread size on 3.9 water pump for fan clutch? Hans Misc. Chit-Chat 1 January 29th, 2005 09:03 PM
