clutch - Defender Source
Old March 19th, 2004, 05:40 PM
jperakis
James Perakis
94 ST
clutch
so when i started my truck this morning, all of sudden it seems the clutch was completly gone. i couldnt get it out of reverse and there was no resistance from the clutch pedal. thing is i replaced the clutch over the summer. any thoughts would be greatly appreciated
Old March 19th, 2004, 05:56 PM
You are out of Clutch Fluid and your Master or Save needs to be replaced. Replace or rebuild them both and save yourself the trouble of having to do the other later on.
Old March 19th, 2004, 06:23 PM
jperakis
James Perakis
94 ST
problem solved... damn master gave out. thanks mike!
remember two things...
clutch
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
