Clunking at slow roll - Defender Source
Old May 4th, 2014, 08:18 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
My 110 has a part-time tcase, lt77 and fairy locking front hubs of which I have very little experience with. She's old so putting everything in low takes a couple attempts. She pops out but has always gone back in okay. After doing some very basic trails and putting her back into 2wd H I now notice that the last 10 feet before a full stop I'm getting what I would describe as some loose chunkiness in the drive train. It seems too loose to be UJs and there seems to be no signs of anything different when under load. In other words No vibes. There is what I would describe as typical rover slop in the drive train.
Does this sound like wear in the tcase to anyone? She's old but has only done about 60k since 83.
My initial thought was to drain trans and tcase fluids and replace with some redline to see if that helps any.
Clay
Clay
Old May 4th, 2014, 04:19 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Mine does the same however it is a full-time transfer case. I just popped the pto cover and inspected the gear/spline wear and found some considerable slop/wear there. There also seems to be excessive slop in my transfer case. Curious as to what you find with yours.
Ryan
Ryan
84 110SW County LHD
07 L322 Vogue
Old May 4th, 2014, 06:46 PM
1of40's Avatar
1of40
1of40
Thanks Ryan
Whining and clunking when decelerating? Quimbola Defender Technical Discussions 5 October 9th, 2013 05:48 PM
Rough shifting and clunking from 1st to 2nd gear Bryanfor311 Defender Technical Discussions 9 May 22nd, 2012 01:18 PM
Brake Pad Clunking Noise hutch Defender Technical Discussions 33 July 15th, 2011 10:02 PM
Clunking While Coasting in Nuetral kzack Defender Technical Discussions 3 September 19th, 2010 01:31 PM
Reverse Light is Slow to Turn On-Why? JRowe Defender Technical Discussions 1 December 12th, 2003 05:03 PM
» Defender Registry
D90 #2326
DM2326
Pumkin
natas
Add your Defender
