Clunk or binding at low speed - Defender Source
Old August 27th, 2013, 10:51 AM
Hudson
Hudson
1987 110 200Tdi
Fairly recently I had a new clutch installed and transmission/transfer case resealed by a trusted British shop. Ever since, I've noticed a moderate to severe rhythmic clunk when I'm just about stopped. Sometimes it's just a noise, but other times it's enough to bounce the suspension. It doesn't seem to matter if the clutch is engaged or not, and there are no other issues with noises while turning, accelerating or decelerating at speed, or reversing. The driveshafts don't seem to have any play in them either. Any ideas on what this might be?
This is on my 1987 110
Old August 27th, 2013, 11:00 AM
Don't like the sound of this. Go underneath and see if they forgot a few cross-member or gearbox mounting bolts or similar.
Old August 27th, 2013, 02:13 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
U joint ?
Old August 27th, 2013, 02:20 PM
Hudson
Hudson
1987 110 200Tdi
I just got a chance to check the mounting and cross-member bolts and they are all tight (and new bolts with either locktite or nylock nuts). That was a relief!
The U joints don't have any play that I can feel and they look well greased. Is there another test I should be doing there? The noise and shudder aren't present at any other time besides coming to a stop under 5mph or so.
Old August 27th, 2013, 02:30 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Sort of sounds like the CDL is engaged.
Old August 27th, 2013, 03:46 PM
Hudson
Hudson
1987 110 200Tdi
I had thought that initially as well... that maybe the shop was verifying the function of the diff lock after putting everything back together. When I was back home in my driveway that day, I shifted the transfer case through all positions to be sure I was fully engaged in non-lock high, but never drove around.
On my lunch break today I pulled into a vacant lot and engaged the difflock, drove a few feet, then disengaged and backed up a good amount to be sure it disengaged fully. I only had time to drive a few more blocks, but the clunking didn't happen. I'll test it some more after work and report back.
Old August 27th, 2013, 06:51 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Radius arm bushing. That's what I have going on. Same symptoms as you only mine doesn't do it when it's dry out, only when it rains.
Old August 27th, 2013, 07:07 PM
Along these lines, I was actually thinking the A-arm ball joint, since it exhibit symptoms as you describe. If the shop had it hanging on a lift (which I'm assuming they did), maybe that stress of the rear hanging could have done it in (if it was on its way out to begin with).
Old August 27th, 2013, 07:46 PM
Hudson
Hudson
1987 110 200Tdi
Sounds like a consensus is forming and I like it! The noise came back on my drive home from work so my diff lock trick didn't work. Will check A arm ball joints next... Thanks guys!
Old September 29th, 2013, 10:10 AM
Hudson
Hudson
1987 110 200Tdi
After a lot of procrastinating, I got the new a-frame ball joint installed. The old one was bad without a doubt and everything was seized solid with rust. However the clunk is still there, just more muffled now. It only happens when coasting to a stop, with or without braking, but not when engine braking. What is the next thing I should check?
Old September 29th, 2013, 09:21 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
I had a similar issue and it was a sticking parking brake. Use a long screw driver, or similar, and see if you can move the lever from underneath the truck. Mine moved a 1/4 or so but it was enough to fully disengage the brake.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old September 29th, 2013, 09:49 PM
Your diff lock could be out of adjustment, but that's easy to check.
Old September 29th, 2013, 11:25 PM
Hudson
Hudson
1987 110 200Tdi
Jeff: I'll check out the bushings. Judging by the rest of the truck, I'm sure they're shot
lordhelemt: after you disengaged the brake, did you just never use it again, or is it a one time thing?
Jymmiejamz: I've never read anything about checking diff lock adjustment, and I suspect this might be the culprit as the problem started after a shop rebuilt my transfer case. How do I check?
Old September 30th, 2013, 07:21 AM
lordhelemt's Avatar
lordhelemt
Paul
My brake is sticking so I'm not using it right now. The Phillips head screw that holds the drum on is stripped so I need to tack a bolt on to it to get it out. I just haven't had time to get into it and see what is actually keeping the brake to completely disengage. I suspect something needs to be lubed or I need to replace the drum springs. Ill post what was the issue if I get to it soon. It's on my very long list of things I need to get too. In the meantime I keep a pry bar in the truck in case I forget and engage the brake
Old September 30th, 2013, 07:29 AM
Jack both front wheels off the ground and see if you can turn them both the same direction. If the centre diff is fully unlocked you should be able to turn them, if it is locked they won't turn.
Old March 24th, 2015, 03:56 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
having same issue
and was wondering if you found a solution?
Attributed to Shayne...
Old March 24th, 2015, 04:05 PM
My read on this is the parking brake.
Old March 24th, 2015, 04:09 PM
kevincdoyle
Kevin C. Doyle
So, as you're slowing down, the parking brake is "grabbing" and causing the clunking? For a shade tree, what is the easiest way to check this out?
Thanks so much!
KCD
Old March 24th, 2015, 04:12 PM
100% ... if i drive with the parking brake on it's exactly as described.
Old March 24th, 2015, 04:19 PM
That would be my guess. Try adjusting it per the manual first.
It can never hurt to pull it and give it an overhaul. Everyone should learn how to do it. Mine comes off at least every couple of years.
Stalling at Idle and switching gears at low speed BEIS Defender Technical Discussions 9 May 8th, 2013 02:33 PM
Low Speed Resistor and Harness hankhowi For Sale - Parts 0 October 21st, 2012 06:26 PM
Whining Noise at Low Speed The Dro Series Technical Discussions 16 October 14th, 2011 06:31 PM
