Clunk Clunk Clunk front wheel - Defender Source
Old October 14th, 2009, 07:03 PM
bjf's Avatar
bjf
barry f
94 ST #395
Driving to work today in the 110 and I hit a small bump in the road. After that the slightest bump i n the road sounds like my passenger side front wheel is going to fly off. Sounds like my spring is broken in half. Seems to drive okay and I am about to do the suspension anyway. Any ideas what to look for?
Old October 14th, 2009, 07:06 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Mabye you broke a cv joint.
Robert Deniro
Old October 14th, 2009, 07:07 PM
bjf's Avatar
bjf
barry f
94 ST #395
damn it
Will it be obvious?
Old October 14th, 2009, 07:14 PM
Neil McCauley
Neil McCauley
Originally Posted by bjf
damn it
Will it be obvious?
I would first get under there to see if its anything obvious (broken shock mount etc) If everything looks alright after a visual inspection your going to have to take the hub apart. Good time to check the wheel bearings as well. Good luck. A bad cv joint usually is a clicking noise especially when turning. Jack up the entire axle and try to spin it by hand and see if you hear the same noise.
Robert Deniro
Old October 14th, 2009, 07:20 PM
bjf's Avatar
bjf
barry f
94 ST #395
damn I rebuilt that hub about 5 months ago.
can i drive it the nine miles home?
Old October 14th, 2009, 07:26 PM
"can i drive it the nine miles home?"
Sure, call me when you need spare parts.
Ron
PS stop on the way home and buy snap ring pliars if you don't have them already
Old October 14th, 2009, 07:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
Ah I just used needle nose pliers. Are snap ring better. I was just in sears.
I have new shocks, springs, securing rings and bolts on the way.
Old October 14th, 2009, 07:40 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Is it a constant clunk when rolling or only when you hit a bump or what not? So you just redid the bearings? So probably not that. Sounds like a shock mount or something suspension related. How long ago did you redo the bearings?
Old October 14th, 2009, 07:52 PM
bjf's Avatar
bjf
barry f
94 ST #395
bearings were about 4 to 5 months ago. Just that wheel. Only when I hit a bump.
Old October 14th, 2009, 07:59 PM
Neil McCauley
Neil McCauley
Who did the work? Mabye they didn't do something correctly. Just a thought.
Robert Deniro
Old October 14th, 2009, 08:03 PM
bjf's Avatar
bjf
barry f
94 ST #395
me!!!!!
http://www.flickr.com/photos/barryri...7613242026920/
Old October 14th, 2009, 08:06 PM
Neil McCauley
Neil McCauley
Ahahahahahahahahahahahahahahahahahahahahahaha
just kidding. hope you figure out what happened
Robert Deniro
Old October 14th, 2009, 08:50 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
If it is only when you hit a bump I highly doubt it was a CV. I would say suspension and maybe bearings but I doubt it also. Jack the truck up and wiggle the wheel. If it feels loose then it is probably hub related. I assume you tightened the lug nuts!!!!
Old October 14th, 2009, 09:05 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
umm, not to sound like a total ass but have you checked the lugs? This happened to a guy I know..
bill
Bill
Old October 14th, 2009, 09:06 PM
Poke around under there and tug and pull on things. Grab the top of the wheel and push/pull violently. If nothing looks amiss visually I am sure you can drive home safely. But it sounds like you need to stop abusing this truck Barry - driving on roads with small bumps and all!
Old October 15th, 2009, 01:44 AM
bjf's Avatar
bjf
barry f
94 ST #395
Well I know it's not the lugs as I just had the wheels balanced and watched the lugs get put on with an impact gun. Anyway, I go outside and look around and grab the front shock and it is totally loose. Only tight on the top. Just rattling around in the spring. Look around some more, the bottom nut is missing. So the shock is only being held on at the top. This is a funny coincidence since I ordered new shocks and springs anyway. Now don't blame me for the nut falling off. I haven't done a thing to the suspension yet. Who puts ranchos on a land rover anyway!!!!
Old October 15th, 2009, 12:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
IS there a bottom shock mount to break or is the bolt all it is? It moves around a bit but the threads still come through the bottom mount hole. I would think the expansion of the shock would hold it in place
Old October 15th, 2009, 12:59 PM
No the springs expand and contract much faster than the shock will on it's own. You should be able to get a washer and locknut for it at the hardware store to tide you over until you replace them.
Old October 15th, 2009, 01:08 PM
Neil McCauley
Neil McCauley
There is suppost to be bushings and washers clamped down by the threaded shaft on the shock and the lower spring mount that holds it all down on the lower mount.
Robert Deniro
Old October 15th, 2009, 01:13 PM
True - you have probably lost the lower bushing along with the nut and washer.
wheel
Right front wheel whine kolvedic Defender Technical Discussions 33 November 2nd, 2011 10:30 AM
front end 'clunk' when braking.. jaherring Defender Technical Discussions 3 September 29th, 2005 12:04 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
