Clock only works when it's cold? - Defender Source
Old January 6th, 2014, 12:41 PM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
My first clock was a champ! Ran great for 8 years then finally died.
Bought a new one and this one only works if it is under 20 degrees outside?! Once it warms up clock stops! Crazy!
Any thoughts?
-Josh
Old January 6th, 2014, 03:21 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I'd suspect it has a solder joint on a circuit board that is bad and only works when cold because of contraction of materials when cold.
Old January 6th, 2014, 03:24 PM
And the winner of the best fault ever award goes to ...
Old January 6th, 2014, 03:57 PM
Move to Alaska and you will always be on time!
Old January 6th, 2014, 06:15 PM
Quimbola's Avatar
Quimbola
Josh
Working well today, it was -16.
I'll take a peak at it.
Old January 6th, 2014, 06:38 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Because electric automotive clocks were always poor performers, that's the primary reason smart phones were invented.
clock
Heavy Duty OME & the works Rover- Girl Wanted 1 January 30th, 2006 09:21 AM
WTB defender dash clock mpodgorski Wanted 3 March 7th, 2005 08:33 PM
D90 Clock Rejuvinated - One fix arbik Defender Technical Discussions 0 March 2nd, 2005 07:34 PM
? for you cold weather people javelinadave Defender Technical Discussions 8 November 24th, 2004 12:34 PM
Factory clock problems Art Vigil Defender Technical Discussions 9 February 11th, 2004 11:20 AM
