Clicking sound with defender tdi 300 - Defender Source
Old May 25th, 2013, 05:45 PM
Merg
Merghani
1997 TDi Defender
Hi guys,
I have an annoying clicking sound coming from the engine when the car warms up an is driving from around 40 kph upwards. Mechanic thought it was brake pump and I replaced it but its still there. Any ideas?
Old May 25th, 2013, 05:48 PM
Change your mechanic ...
Old May 25th, 2013, 06:40 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
If it clicks in constant time (doesn't change with the RPM's) put your finger on the purge valve to see it you can feel the vibration that matches the click. Had the same issue recently. It was my Hyundai purge valve ($21 instead of $200 for LR part) doing its job - but LOUDLY.
Old May 25th, 2013, 06:48 PM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
Its the fuel pump, trust me. The one attached to the block aside from the vaccum pump. Do you hear the clicking like if it came from the chassis, or engine bay?
Cheers,
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old May 25th, 2013, 06:49 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Have ever checked your tappets? seeing this is your first post watch out for wrong information. you have no purge valve on a 300tdi
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 26th, 2013, 04:31 AM
Merg
Merghani
1997 TDi Defender
Cheers,
It sounds more like its coming from the engine bay.
Cheers
------ Follow up post added May 26th, 2013 02:33 AM ------
The clicks increase with rpm but can't be heard when the car is stationary. Has to be moving. And the strange thing is that when the engine is cold you won't hear it for a while.
Old May 26th, 2013, 08:37 AM
Cube II's Avatar
Cube II
Michele
1997 D90
I have the same issue but can't remember if being warm or cold makes a difference.
Some on the web suggest the brake pump as well, I rebuilt mine not a long time ago...and it still leaks
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old May 26th, 2013, 09:28 AM
defeyago's Avatar
defeyago
Santiago
If it does when stationary and you hear the clicking go under the car and touch (feel) the fuel lines that go on top of the chassis to the tank in the rear. If you feel like a pulse on them its the mechanical fuel pump for sure.
Check valve clearance if not the above.
Cheers,
SANTIAGO
Old May 26th, 2013, 09:36 AM
Merg
Merghani
1997 TDi Defender
Cheers,
No unfortunately the sound is only there when its moving. If its the fuel pump, does it need to be changed or can it be serviced?
Old May 26th, 2013, 10:03 AM
defeyago's Avatar
defeyago
Santiago
It cant be serviced as I know, I always change them, not expensive thing. It should do the clicking when stationary at some point if where talking the same thing.
Cheers,
SANTIAGO
Old May 26th, 2013, 06:40 PM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
I have not had the problem that you describe, but I am thinking it might be clutch/tranny related. Something on the input side of the gearbox.
It would be engine RPM dependent, and if the fault required it to be under load to make the noise, that would explain it not making noise when the truck is stationary.
This is purely guessing.
See if it clicks when the engine is warm by lugging the engine with the parking brake on. That would put the engine under load, but not have the input shaft spinning in the tranny. If it makes the noise, it is not the gearbox, and really is engine related.
75% of all Land Rovers ever made are still on the road...
the other 25% at least made it home.
300 tdi cross members Oliver Whiting For Sale - Parts 2 June 15th, 2011 08:00 AM
1980 Land Rover Defender 300 tdi on Ebay jessejames4 The Flea Market 5 January 8th, 2008 01:57 PM
94 POE 90 or 95 300 TDI Disco FS SafariHP For Sale - Vehicles 1 October 15th, 2007 09:31 PM
WANTED: 300 tdi radiator, new or used. In a bind! dmarchand Wanted 0 June 30th, 2005 04:35 PM
