Clicking on startup, DOES Start - Defender Source
Old July 21st, 2013, 04:09 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
via my searching and basic knowledge, I know the deadly clicking is a sign of started failure when the engine doesn't turn over. My engine IS still starting, but gives a few clicks (this is new 3 days ago) while it is turning over. I dont hear the clicks and then it starts. Its all happening at the same time. This started happening since I mistakenly turned over the ignition while it was still in gear and it lurched forward.
Obvi if my starter is going or on its way out, would love to replace before I have the click of death or need to go under the truck and beat it with a hammer just to get home.
TIA for any insight.
Old July 22nd, 2013, 04:01 PM
josh-man's Avatar
josh-man
joshua
Bump
Old July 22nd, 2013, 04:49 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Why don't you crawl under the rig and gain some experience/knowledge. First make sure your electrical connections are german "Gud-n-tite" on the starter and battery. Second do the same to the mounting bolts of the starter. If it persists then go on and change the starter before it leaves you stranded. You don't really need the starter anyway as long as you can learn to park on hills and pop-a-clutch. Good luck!
Old July 22nd, 2013, 06:12 PM
Sounds like a poor ground which is the fastest way to burn up a starter. Run an additional ground wire from battery neg post to one of the starter bolts. May be too late but I burned up a winch motor with an insufficient ground. Do as I say not as I do...
Old July 22nd, 2013, 08:32 PM
josh-man's Avatar
josh-man
joshua
Oh, I've been under the rig, so to speak, my friend. Connections are tight. I mean, I'm new to my defender but not a moron.
May take the below advice though to see if that helps.
Appreciate the advices.
Old July 22nd, 2013, 09:04 PM
Like starter solenoid clicks when you turn the key? And no starter action?
Old July 22nd, 2013, 09:09 PM
josh-man's Avatar
josh-man
joshua
That's the only thing I can relate the sound to. But it made the clicking as it was starting and I've yet to have it just click click with nothing else but have had that happen in my other rovers.
Of course tonight and last night I had her out, and it didn't do it. Just started right up and sounded normal.
Hmmmmm
start
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
