Clicking noise from behind IP - 97 D90 - Defender Source
Old March 25th, 2006, 04:59 PM
Saito
Dale
Hello all -
need some help - guys at the local LR shop say they don't know what it is. 1997 D90 NAS. 76k miles - driving down freeway and clicking noise started up - thought I had my turn signal on - nope - nor the emergency flashers - yet that is what it sounds like - coming from behind IP. If you pull the 30amp fuse under the eng compartment fuse box - clicking stops. this fuse "description" shows an open textbook like figure. Ckeck engine light was on several hundred miles prior ( slow responding o2 sensor - they just reset it the last two times in at the LR shop and has went several thousand miles without another "glitch")
Took out IP - there is a green box attached to upper upper portion IP housing. measures about 1" thick, 3 1/2 in wide - 5 in length. Has two wiring connector packs going to it - one with a green connector, the other appears grey. If you pull the green connector out - clicking inside box stops. - pulled both green and gray connector out as suggested by LR tech at local shop - he thought he had one several years ago and that is all he did to "fix" it. Did that - still has click noise.
He also thought it has something to do with an interia switch - but wasnt sure. Dont care to spend $100 per hour for guessing... at least not this time.
The shop manual I have does not mention anything about this part
Any ideas folks??
Thanks in advance!
Dale
Old March 25th, 2006, 11:40 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
Dale, check this out
jeff
Old March 26th, 2006, 01:38 PM
Cholla
Jack Copass
97 D-90 SW
Hey Dale, I had this problem occur once during a heavy rain, and I think it got wet. It was this same Immobilization Control unit (alarm ECU). Sounds just like a turn signal clicking, as you said. Mine stopped after turning the key off, and letting it sit for a while. If that continues for you, I would replace it.
Jack
Old March 28th, 2006, 11:17 AM
Saito
Dale
THanks!
jeff
That's it!
thanks guys!
Jack
I think I will - according to the guys at the local LR dealership - my vehicle is not suppose to even have this item in it... but it is going to get a new one!
THanks
Dale
90, 97, 97 d90, d90
headers for '97 D90 mdmccallum Defender Technical Discussions 43 April 25th, 2005 10:23 AM
I've Got A 97 D90 Frame That was just Galvanized ksteven Defender Technical Discussions 21 March 24th, 2005 11:22 AM
OEM MAF sensor from '97 D90.... dmarchand For Sale - Parts 4 June 18th, 2004 06:49 AM
97 D90 maxing out at ~70mph?? vnrover Defender Technical Discussions 3 November 10th, 2003 02:14 PM
For Sale: '97 D90 ST-1791 Alpine White jwebster For Sale - Vehicles 0 September 30th, 2003 12:36 AM
