Clicking in 4th and 5th gear - Defender Source
Old August 9th, 2010, 08:03 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
I had a great weekend with my truck running sand dunes in Silver Lakes Michigan. Truck ran flawlessly the whole time we were off the pavement. A lot of high revs while running the dunes and hills. Moderate speed through some water but only 1 to 2 feet deep.
Drove home almost 300 miles with no problems. Since I have been home my truck has a weird ticking sound when I am in 4th and 5th gear. Not sure but it almost sounds like the truck is out of gear.
Any ideas or help on what it could be?
Clarence
------ Follow up post added August 9th, 2010 08:14 PM ------
I should mention the noise I am hearing is more audible when I am in 4th or 5th and the truck is decelerating. It sound like a ticking as the speed reduces the ticking slows.
Old August 9th, 2010, 11:04 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
If this was Car Talk, I'd put my money on a catalytic converter that is nearing the end of it's life.
Old August 9th, 2010, 11:51 PM
andyrad
Andy Radlgruber
None.
I don't think that there is much about a vehicle that would make it click in 4th and 5th. I would look at wheel bearings or u-joints. Sand and water don't mix well with a damaged seal and grease. I once had a clicking from the rear end and thought I had a u-joint on the way out. When I took out the rear axles to install a locker later that day I realized I was lucky that I didn't lose my rear wheel. Bearings were pooched.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old August 10th, 2010, 12:57 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
I'll check that tomorrow.
------ Follow up post added August 10th, 2010 12:04 AM ------
Greased the ujoints before and after. Might be some more sand to get out.
Old August 11th, 2010, 12:19 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Greased the u joint on the front shaft and now I noticed there is a problem with the seal on the u joint. The seal is not secured in place anymore. I am not sure how to correct the problem. The shafts are from relatively new (January 2010) from GBR.
I think this may be the cause of my mystery noise. Did I fubar it?
So what to do to fix this? Any help is appreciated.
ID:	30038   Click image for larger version
Old August 11th, 2010, 07:33 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Bump
------ Follow up post added August 11th, 2010 06:36 AM ------
Originally Posted by Cred
Bump
Do I need to pull the shaft off to get this repaired or can I repair this myself and leave it in place?
Old August 11th, 2010, 04:49 PM
andyrad
Andy Radlgruber
None.
I have always greased u-joints until the grease starts to ooze out of the rubber seals/cups, thus displacing the seal, if that is the seal you are talking about.
The cap inside the yoke seems to be displaced as well from the slip yoke travelling a bit too far or the amount of grease inside pushing it off during compression. If anything on your drive shaft was clicking it would probably be at the same rate of the shaft, which is fast. If the clicking is slower it could be wheel or axle related. Maybe just as simple as a rock in your tire.
Crawl under your truck with the rear end jacked on stands up and t-case in neutral and spin the tires by hand to see if you hear anything from there.
Transfer case whine ini88 Defender Technical Discussions 30 May 7th, 2012 09:46 AM
Clicking in tranny when downshifting from 5th to 4th DonFromWhitby Defender Technical Discussions 5 October 1st, 2009 02:46 AM
R380 ini88 Wanted 6 May 19th, 2009 12:42 AM
95 D-90 5th gear broken DG Rodgers Defender Technical Discussions 4 February 19th, 2009 10:06 AM
Linkage - gear box shot ? My 1st time (pop!) paulb Defender Technical Discussions 10 January 21st, 2008 07:07 PM
