Clicking/Fluttering Sound at WOT - Defender Source
Old February 28th, 2009, 01:15 PM
fleabus's Avatar
fleabus
Dan
None :(
Just some proactive troubleshooting here and/or possible paranoia
Recent 4.6 swap and at WOT or heavy acceleration I hear a clicking or metallic fluttering sound from the engine (not quite like lifter tapping, but similar). Hard to describe the sound, but I have heard it before in other cars... like when you are heading uphill in an automatic in too high a gear.
Truck runs fine at normal acceleration and no odd sounds are observed.
Any ideas? Normal?
Old February 28th, 2009, 02:15 PM
Sounds like pinging.
Old February 28th, 2009, 02:45 PM
btate
Bryan Tate
d90
did you put a fuel chip in? My 4.6 did the same until I put a chip in and I haven't noticed it since
Old February 28th, 2009, 07:12 PM
fleabus's Avatar
fleabus
Dan
None :(
The shop that did the swap put in a chip, but who knows what kind or where they got the chip.
What are you drunning in yours?
Old March 2nd, 2009, 06:00 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Crankshaft counterweight hitting the oil pan....? If you put the steel 3.9 oil pan on a 4.6 it requires clearancing at the front or the counterweight will just touch the inside of the front of the pan. Clearancing is accomplished with a torch to heat the pan and a bit of hammering to move the metal about 3mm. If this is the problem you will probably be able to feel it by holding your hand against the shallow part of the oil pan when it is running. It will leave a shiny mark so you know where to give it clearance.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old March 2nd, 2009, 10:28 PM
fleabus's Avatar
fleabus
Dan
None :(
It was a 4.0 --> 4.6 swap (same oil pan?)
Old March 3rd, 2009, 11:08 AM
Roadsiderob
Robert Dassler
1994 D90
Yeah, the 3.9 and the 4.0 use the same oil pan. The crank counterweights are bigger on the 4.6L crank and all of the swaps I've done required clearancing the pan.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old March 3rd, 2009, 11:12 AM
fleabus's Avatar
fleabus
Dan
None :(
Interesting... what you describe sounds like how I imagine the sound originating (at least in my mind)... almost like pinging, but a slightly more metallic noise under heavy acceleration. If this is the casse, any reason why I wouldn't hear the sound under normal operation?
Old March 3rd, 2009, 11:29 AM
Roadsiderob
Robert Dassler
1994 D90
As rigid and tight as an engine is, things still move and flex a few thousandths of an inch under different loads. It may take WOT or heavy acceleration to flex things enough to get contact. It could still be pinging....but I know for a fact that all of the 4.6L swaps I've done required clearancing the pan....and I figured it out after I had what sounded like a bottom end tapping noise on the first one.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old March 3rd, 2009, 11:36 AM
fleabus's Avatar
fleabus
Dan
None :(
Got it... thanks for the advice.
I'll check it out this weekend and report back.
does this sound like a rover V8 rover4x4 Misc. Chit-Chat 4 January 5th, 2006 06:24 PM
Sound Dampening Material kellymoe Misc. Chit-Chat 1 March 13th, 2005 01:34 PM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
