clearing fault code - Defender Source
Old March 19th, 2008, 10:01 PM
phunter
phunter
1993 NAS 110
Question clearing fault code
I have tried the series of steps listed in the FAQ section. After switching the ignition off and hearing the relay drop, I still see code 17. I do not know if I have other fault codes, for I cannot get a blank screen.
When I kill the power I get code 02. After letting the truck idle for around 10 minutes, it idles down and then Check Enginecomes on followed by code 17. Any help would be greatly appreciated. I have repeated the steps of unplugging the code box afew times. Thank you.
My truck is NAS 110.
Old March 20th, 2008, 02:16 AM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
try this
Try This
Here they are
Name:	clear codes.jpg
ID:	12702   Click image for larger version
ID:	12704   Click image for larger version
Old March 20th, 2008, 05:39 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Code 02 is nothing to worry about, it just means that the ECU was recent recently. Normally it goes away once you turn the truck off.
Code 17 indicates a failure of the throttle position sensor. Easy to replace, but a bit spendier than it needs to be... $60 or so for the part depending on where you go.
My oil line fix
My 100k stopped odometer fix
Old March 22nd, 2008, 07:53 PM
thecatsmeow
Michael Morgan
1994 D-90 ST
5 Minutes Max
I had the identical fault 17 TPS just a few months ago. Easy access swap out, disconnect/reconnect the + terminal, start the truck, check code should stay 02 with no pesky check engine light on. I sourced the part from friend in Shelby, NC. Evan Amaya at Reborn Company. http://www.rebornco.com/ There is a Bosch generic.....looked identical, works fine. Morgan
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 10:54 AM
Fault Code "03" Doug Defender Technical Discussions 15 July 18th, 2005 10:38 PM
Fault Code 19 chrisvonc Defender Technical Discussions 17 April 29th, 2005 05:28 PM
Fault Code Help howellm70 Defender Technical Discussions 1 January 30th, 2005 05:43 PM
Fault Code 45? Troys Defender Technical Discussions 2 October 20th, 2004 01:04 AM
