Clearing codes for 94 D-90 - Defender Source
Old April 14th, 2005, 02:54 PM
ripp2002's Avatar
ripp2002
L C
94 Defender 90
Does anyone know how to clear the codes for a 94 D-90. I printed some items off this site but that method does not seem to be working. Wanted to know if anyone has other methods. Thanks for the help ahead of time.
Larry
Old April 14th, 2005, 02:58 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
On mine all I do is disconnect the battery for about 5 minutes. Works every time. Others have reported various success with that method.
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old April 14th, 2005, 03:02 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Unplug the bulb in the dash?
Just kidding, you don't want to ignore the check engine (yellow) light. It should reset itself after several on-off cycles if there are no faulty sensor reading. You can pull the bulb for the service engine light (red) if you don't want to take off your AC to reset the emissions timer.
Old April 14th, 2005, 05:30 PM
tron's Avatar
tron
Thomas F
Recently Roverless
I broke down and bought an OBDII scanner at Auto Zone. They have one which is really simple and costs around $75.00.
Old April 14th, 2005, 05:55 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
OBDII only works for 97's. 94&95 Rovers are OBDI. Just FYI. Don't know if the OBDII scanner is backwards compatible with earlier cars.
Old April 15th, 2005, 01:39 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
yeah, I have it. I will dig it up. I remember it had something to do with the white wire....
90, d-90
90 & 110 Parts Sale Extravaganza Wolf Fabrication For Sale - Parts 57 October 16th, 2012 09:35 AM
Electrical Issues & the best repair manuals for a 1995 D90 agavelvr Defender Technical Discussions 18 August 23rd, 2011 12:54 PM
Clearing the OBD? DJ Menasco Defender Technical Discussions 13 August 1st, 2007 09:01 PM
Fault codes OBDI & OBDII Art Vigil Misc. Chit-Chat 3 September 27th, 2004 03:43 PM
Stalling problem and fault codes James Defender Technical Discussions 5 July 22nd, 2004 07:29 PM
