Clearing "Check Engine" - Defender Source
Old May 15th, 2008, 09:44 AM
jcollinge
James Collinge
1997/D90
I replaced the Mass Air Flow sensor and tried to clear the codes. LR said that the MAS was the issue causing the light to go on. Unfortunately, the code reader does not report any codes that have fired, and I can't use it to clear the light. Am I missing something?
Thanks for the help...
Old May 15th, 2008, 10:05 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
unplug your abs under the pass seat and try again. I assume you have a compatable reader for the truck.
Old May 15th, 2008, 10:35 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
disconnect the battery for 10-15mins
3rd low and BOOT IT
Old May 15th, 2008, 01:44 PM
jcollinge
James Collinge
1997/D90
Thanks guys I'll try it today. I'm using the Can-TEch 94169. I'm assuming the ODB II compatible interface on the D90 works with this unit. Seems to be reporting correctly.
Old May 15th, 2008, 03:54 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Only works on us pre OBDII guys (aka not 97's), jimmy.
engine
"Service Engine" Light Flicker Wolf Fabrication Defender Technical Discussions 2 January 14th, 2009 06:25 AM
clearing fault code phunter Defender Technical Discussions 3 March 22nd, 2008 07:53 PM
Clearing the OBD? DJ Menasco Defender Technical Discussions 13 August 1st, 2007 09:01 PM
Another "Check Engine" issue cwadswor Defender Technical Discussions 2 October 15th, 2006 01:02 PM
Clearing codes for 94 D-90 ripp2002 Defender Technical Discussions 5 April 15th, 2005 01:39 AM
