Clear Lense Bulb Number? - Defender Source
Old April 15th, 2012, 10:04 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
Over the weekend I rewired all of my new LED's and Front clear lenses. The problem I have ran into the bulbs are called out for the top front parking lamps # 5008 (only offered in clear).
Issue is no one offers these in amber and Safari Hp informed me not to use a larger bulb #1156 (stated it will melt the lense). Anyone had this problem or suggestions for another amber buld that will fit without problems? The truck in the photo is not mine, however I do have the same clear top and bottom lamps. Thanks for the help!
Name:	clear lense.jpg
Old April 15th, 2012, 10:09 PM
Naplm00
Matthew
I left mine clear, looks like a running lamp
Old April 15th, 2012, 10:14 PM
Rosproline157
Matt Oaks
1992 Defender 90
state inspection???
Old April 15th, 2012, 10:23 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Should be exempt if its an import on the 25 yr basis shouldn't it?
I used Amber LEDs in mine, can't see why you couldn't go that route? Its the color of the light that matters, not the lens.
Old April 15th, 2012, 10:24 PM
Naplm00
Matthew
yea, any other light besides the amber blinker is ignored in my area
Old April 15th, 2012, 10:32 PM
Rosproline157
Matt Oaks
1992 Defender 90
I understand that the color matters, that is the topic of discussion. Are you satisfied with your LED Brightness? Also, Which LED's did you use and where did you find them? Did you use resistors?
I did look on ebay and they are allover it. However most do not list true sizes of the bulbs. Ebay, lists numerous cross references but very few 5008's.
------ Follow up post added April 15th, 2012 10:33 PM ------
Be thankful.
Old April 15th, 2012, 11:21 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
I used 67-A15 LEDs from SuperBrightLEDs.com. My lenses are amber but you should get a similar result with clear ones (see pic of bulb only). I am happy with mine.
ID:	50373   Click image for larger version
Old April 16th, 2012, 08:12 AM
Rosproline157
Matt Oaks
1992 Defender 90
Perfect! Thank you very much.
Did they require resistors or speed up your flashing pattern?
Old April 16th, 2012, 01:54 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Yes these are the side lights, parking lights, running lights, whatever you want to call them. They are clear on ROW trucks and Amber on NAS. The bottom ones should be your turn signals and are always Amber except on some later ROW trucks. No resisters needed for the side lights, just fit the bulbs and go. You can always buy some Amber lights if you are really concerned about it but its easier and cheaper to just buy the bulbs. LEDs won't melt your lenses either.
Old April 16th, 2012, 09:43 PM
Rosproline157
Matt Oaks
1992 Defender 90
Ordered the LED's Thanks for the help!
Part number for front marker lenses? Hans Misc. Chit-Chat 4 December 3rd, 2005 11:00 PM
clear housing as opposed with amber njdef90 Defender Technical Discussions 9 January 22nd, 2005 09:01 PM
Clock Light Bulb ronward Defender Technical Discussions 1 April 28th, 2004 04:13 AM
Clear lens for running lights PT94D90 Defender Technical Discussions 5 April 9th, 2004 07:28 PM
Side lamp bulb holder Neo Defender Technical Discussions 5 January 30th, 2004 05:07 PM
