Cleaning the cylinder head intake without removing - Defender Source
Old August 31st, 2014, 09:17 PM
MotoMando
Armando Centeno
1997 Defender 90 SW
With the rocker assembly remove, is it safe to assume all the valves are closed. I want to clean the intakes in the headers without removing the cylinder heads. I'll be blowing out the carbon buildup with compress air after scrubbing.
Old August 31st, 2014, 09:25 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Its best to pull the plenums.
Old August 31st, 2014, 09:43 PM
MotoMando
Armando Centeno
1997 Defender 90 SW
Yep. The upper and lower plenums are already removed. I want to make sure carbon buildup doesn't get into the cylinders while cleaning.
Old August 31st, 2014, 10:02 PM
Yes.
vin
intake hose without the MAF cdb Series Technical Discussions 0 November 26th, 2011 08:46 PM
200 tdi cylinder head? Hoosier Defender Technical Discussions 10 July 7th, 2009 07:29 PM
Cylinder head bosch with seconday air budz For Sale - Parts 2 June 23rd, 2009 04:31 AM
Southwest Rovers Cylinder Head chris snell Misc. Chit-Chat 1 August 21st, 2007 10:31 AM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
