Cleaning Oil Breather Cap 2.5TD ETC7774 - Defender Source
Old July 20th, 2014, 07:50 AM
richord
Richard Ordowich
1987/D90
Can the breather cap (the one with two hoses connected) on a 2.5TD be cleaned? If so how should it be cleaned?
Old July 20th, 2014, 11:02 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Richard,
Yes it can be cleaned some caps have baffles or wire gauze inside, others just have an empty void that can get gummed up - remove it and leave to soak in diesel overnight agitate occasionally drain & dry it before refitting.
Same thing with the pipes if they are not new.
regards
Gren
Gear oil burped out through breather hose Tyler Wirken Defender Technical Discussions 1 February 13th, 2014 10:26 AM
Oil Pan Cleaning 97-D90-736 Defender Technical Discussions 6 July 3rd, 2009 06:37 PM
2.5td heavy breather CDNRover Defender Technical Discussions 18 April 6th, 2009 05:59 PM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
Greese fittin an breather toob rover4x4 Defender Technical Discussions 4 December 30th, 2003 11:49 AM
