Cleaning engine parts - Defender Source
Old April 3rd, 2011, 02:58 PM
61rover's Avatar
61rover
John Crouse
What's the best way to remove the brownish laquer-like finish on engine parts? That's the best solvent?
I'm assuming I don't want anything abrasive. I thought about getting one of those cloth wheels for my bench grinder.
Old April 3rd, 2011, 04:15 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Take to a machine shop to get a chem bath or sonic bath.
Old April 3rd, 2011, 06:27 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've had good luck with Purple Power.
Which engine parts specifically?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 3rd, 2011, 07:47 PM
Dishwasher. Seriously.
Old April 4th, 2011, 02:52 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Only if you are single. Or want to be. Seriously.
It's pretty hard to beat good ol' gasoline. Just put out your cigarette first. Or was that for non-dairy creamer?
Tony
1984 110 "Smokey" (sold)
Old April 4th, 2011, 08:28 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
X2.
I'm not sure what parts you are talking about but while you may get the surfaces with a solvent, you will not get the cavities and oil passages. In fact, you may end up with debris in these areas by surface cleaning.
Old April 4th, 2011, 11:31 AM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
I use oven cleaner on my blocks. I then pressure wash them and spray them with a light coat of oil to keep them from tarnishing before storage. It makes them super shiny but it does strip EVERY bit of lubricant off so make sure you coat them with something to stop any rust from forming.
Old April 4th, 2011, 12:57 PM
Naplm00
Matthew
Purple power works really well. I usually spray on a warm engine, work it in with a brush and let it sit for a while. Then rinse with a hose.
Off engine I usually use purple power or oil eater, brush then blast with beads
Old April 4th, 2011, 11:02 PM
Anything aluminum you can clean with detergent. Do not use caustics like lye or oven cleaner. I don't like using solvents, they're nasty.
Cast iron and steel use lye. My "Jeffrey Dahmer" bucket is a mixture of one can Red Devil lye per two gallons COLD water and 1/2 cup Simple Green. Mix slowly in a plastic tub deep enough to submerge your parts. Soak parts at least over night and rinse with lots of hot water. If the parts are rusty too then you can convert the rust using a 2 amp battery charger. Wire the grotty parts to the negative side and to the positive side attach a chunk of clean steel. Let that sit over night and rinse the slimy rusty ( now converted ) goo off with hot water. Be sure to use a fat wire so that it does not get hot from resistance and don't let the pos and neg parts touch. Stubborn rust may take longer and require turning. You will have bare clean cast or steel parts that will flash rust. A quick spray of Metal Ready quenches the flash rust and preps the surface for POR-15 or primer.
Old April 5th, 2011, 08:06 AM
turbodave
Dave C
1983 110
The best stuff I've ever come across is Dynatex Gasket remover. This stuff is essential to have for softening rock-hard gaskets to avoid scraping alloy housings or engine blocks.
I did a test on a set of discovery 4.6 pistons that had done 120K and were covered in shiny, hard-baked on carbon.
I tried using Mopar combustion chamber cleaner, two brands of oven cleaner and the dynatex. The best by far was the gasket remover. It just pickles away the goop on the surface and allows it to be wiped or brushed off. Unlike the over cleaners - it is also reccomended for use on aluminum.
It is nasty on your skin, and you don't want to inhale it though, so use latex gloves - and double-up. If you use one set of latex gloves and it gets on the outside, your skin gets hot - even though the latex remains intact! Two gloves seems to work perfect. Safety glasses are also ESSENTIAL
If you have a block, heads, pistons, rods, etc, it might be easier just to pay $50 and have the machine shop do it. But the laquer finish on the inside of blocks and heads is no-match for the dynatex, just spray it on, wait 5 mins, and scrub it with a brush. The best brush I've found for small stuff is a denture cleaning brush as these have small, but very stiff bristles. DollarGeneral sells the best ones (just a dollar would you believe") I buy a few whenever I am passing by the place.
oh - don't try the junk gasket remover by permatex from pepboys, oreilys, autozone in the toothpast tube - the dynatex is in a spray can and the best of all brands. Cheapest place to get it is from ryderfleetproducts.com - as an indication of how good this stuff is - it cannot be sold in california!
Old April 6th, 2011, 11:31 AM
61rover's Avatar
61rover
John Crouse
Thanks everyone. Several things for me to try.
engine, part, parts
F/S fastback top & engine parts RX6RCROL For Sale - Parts 1 April 6th, 2006 07:55 PM
TD5 Engine - Parts? Zimbo76 For Sale - Parts 4 October 10th, 2005 11:54 PM
stupid queston, Cleaning my engine RickM Defender Technical Discussions 9 April 27th, 2005 12:55 PM
Engine Cleaning cbass Defender Technical Discussions 1 September 4th, 2004 08:45 PM
