CLD question / front end vibration - Defender Source
Old June 12th, 2013, 08:05 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Other than the light how can you tell if the CLD is engaged? I've got some nasty vibration in the front part of the drivetrain but the usual (ujoints/suspension/brakes) all check out. Its most noticeable when coming to a stop. Happens with or without brakes with the clutch in and in gear or out and in neutral. Feels like its coming from the front end of the tcase.
When I moved the CLD lever over to engage the light came on and the problem didn't get any worse or better but when I moved the lever back over the light is still on so I'm wondering if its possible that it somehow got engage and that's whats causing the vibration.
If its an easy fix i'd like to address it tonight before the big rains.
Thanks in advance
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old June 12th, 2013, 08:07 PM
RoversNorth
RN
2012 Land Rover Defender
Turn the steering wheel all the way to the left or right and drive in circles, you will know if your CDL is engaged.
Rovers North
1319 Vt Rt 128, Westford, VT 05494
Please message me with any questions you have.
Old June 12th, 2013, 10:07 PM
lordhelemt's Avatar
lordhelemt
Paul
It's disengaged (at least it's not fully engaged). I moved the lever directly at the t-case and when locked front and rear driveshafts are locked, when open I can turn the front wheels. Question is can CDL be partially engaged? Most of the vibration is gone but I can still feel it on occasion. Just when coasting or braking to a complete stop, either in gear and clutch depressed or in neutral. Whenever there is a load (ie accelerating or decelerating in gear) no vibration.
Old June 13th, 2013, 02:21 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Be sure all the wheels well balanced. I've chased front end vibes until I finally thought about the wheels. In the end that made a big difference.
Series III - Front end veers hye1978 Series Technical Discussions 5 August 22nd, 2011 01:33 AM
Front bumper end caps One Ten Wanted 8 August 9th, 2011 12:18 PM
defender front end for series mountainviewrover For Sale - Parts 8 July 19th, 2007 08:40 PM
Something Wrong With The Front End? The Wizard Defender Technical Discussions 13 October 4th, 2006 11:51 PM
Front End Wobble RyanS Defender Technical Discussions 7 April 13th, 2004 05:21 PM
