Clanking noise from rear diff - Defender Source
Old April 29th, 2010, 06:10 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
The noise I was getting that I thought might have been a bearing is in fact coming from the rear diff. It sounds like a metal rod hitting something spinning and bouncing off it. Comes and goes but has become much loader and steady...any ideas? I searched and couldn't find the exact thing. Oil is full.
Old April 29th, 2010, 06:14 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Jack up the rear axle and put it on stands. If you trun one wheel does the other turn? Try from both sides. opposite wheel should turn in the opposite direction to the one you are turning with the parking brake on or in park.
If one wheel turns and the other doesn't you most likely have a broken shaft on the side that turns on it's own.
Old April 29th, 2010, 06:30 PM
The shafts are easy to pull and inspect too. If you are running alloys, pull the wheel, then undo the ring of bolts around the flange and pry it out. Should pull straight out with little or no resistance. You'll know if they are broken. If not, just reinsert (keeping them level so as not to put too much pressure on the seal as you push it in) and bolt it up. You can put a little right stuff around the seal if needed.
Old April 29th, 2010, 06:34 PM
Campbell's Avatar
Campbell
Rich Campbell
I will try both...thanks
Old April 29th, 2010, 06:40 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
If both wheels turn from both sides, is it smooth while turning (there will be some play between the wheels, that's normal)? If it grates, is clunky or hesitant (hard to describe, sorry), then you either have a bad wheel bearing (you should hear that right by you on one side as you're turning), or you have something bad in the diff itself (carrier or spider gears broken or Ring/Pinion missing teeth).
Old April 29th, 2010, 06:50 PM
Take the fill plug out and shine a light inside. Stick a screwdriver in the fill plug and see if you can move the spider gears in and out. On rover diffs sometimes the spider gears wear into the case creating a lot of slop and an eventual cross shaft failure.
Old April 30th, 2010, 11:55 AM
Campbell's Avatar
Campbell
Rich Campbell
Put on Jack stands. Both wheels spin and the other in the opposite direction. No noise. Bearings seem tight. Must be in the diff and not the shafts
Old April 30th, 2010, 12:02 PM
You have to pull the shafts to get the diff out. Start there I'm not convinced the spin test is good since there is no load. You could have a reasonably clean shear on the shaft and not tell without load.
But if you think it's the diff, pull it. Pay attention to the shafts as they come out. Diff comes out easy after that.
I broke a cross pin once and I'm pretty sure it locked up the diff when it broke. Not sure what other symptoms to expect from diff damage but it should be obvious once you have it out.
Old April 30th, 2010, 02:36 PM
Campbell's Avatar
Campbell
Rich Campbell
Going out to pull both shafts. Thanks
Old April 30th, 2010, 02:47 PM
You are welcome to drive it down to my place tomorrow. I have a diff and axles (albeit ABS 10 spline ones) that we could swap in. Dom and I are working on the "109/110" project and his BMW motorcycle.
Ron
Old April 30th, 2010, 04:48 PM
Campbell's Avatar
Campbell
Rich Campbell
Pulled both....they don't look broken. Worn a bit flat in spots.
Old April 30th, 2010, 04:49 PM
Pictures? Hard to tell what you mean by flat.
Campbell's Avatar
Campbell
Rich Campbell
Thanks Ron.... I would take you up on that but I'm working all day Saturday. Thanks for the offer though.
Old April 30th, 2010, 04:59 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Just a quick thought but check the drive members are not worn and a sloppy fit on the drive shafts, though this normally causes a clunk when going on and off power..
regards
Gren
Old April 30th, 2010, 05:06 PM
Well, that's where this all started. Although Rich, you never confirmed the u-joints were ok.
http://www.defendersource.com/forum/...ad.php?t=25244
Old April 30th, 2010, 05:44 PM
Campbell's Avatar
Campbell
Rich Campbell
The u joint seems tight....I will check it again...not sure checked it with everythig in neutral and one side jacked.
Will check that next....as always thanks for all the great advice and thanks again Ron for your offer.. Are u around on Sunday at all?? Any downside to swap out for the ten spline?
Old April 30th, 2010, 10:19 PM
I will be around all day sunday until dinner time. You have my cell. Only downside to 10 spline is they are slightly weaker but on a stock truck I doubt you will have any issues with them. I can pretty much guarantee that your stock diff is worn.
Ron
Old May 3rd, 2010, 09:26 AM
Campbell's Avatar
Campbell
Rich Campbell
Ron and I swap out my diff on Sunday with one he had in is VAST parts collection. I have seen first hand the beauty that is the Parts Ninja's stash. Engines, transmissions, tcases everywhere! Not to mention the 110 he is building!
Anyway thanks again Ron for you help. We swapped in a new diff and the noise was still there. We drained the Tcase and the fluid looked new with no metal. The u-joints seem tight and the tranny shifts perfectly. It's heading the the mechanic to see if he can't figure it out. Oh the joy of land rover ownership
Thanks again Ron for your generosity with your time and diff.
Rich
Old May 3rd, 2010, 12:26 PM
No problem rich. Sorry that was not the issue. The stock diff in the rear of Rich's truck was worn (spider gear eating into the stock housing so that I could get a finger nail in the gap) and thought the "new" diff would fix it but no. I am assuming T-case at this point, but Frank the rover whisperer will know for sure.
Ron
Old May 3rd, 2010, 02:41 PM
Campbell's Avatar
Campbell
Rich Campbell
Ron
By the time I got home the noise was full on. This mornings drive in to work nothing to very faint. This is ridiculous.
Rear diff replacement options cgalpin Defender Technical Discussions 20 July 14th, 2007 01:21 AM
110 rear diff clunk D90user Defender Technical Discussions 14 November 19th, 2005 01:49 AM
NAS 90 rear Diff whistler110 Defender Technical Discussions 27 February 3rd, 2005 03:04 PM
rear diff and rear seatbelts for '94 D90 rover_rich_d90 Wanted 1 April 20th, 2004 08:54 PM
