Clanking from Front End - Defender Source
Old March 28th, 2010, 08:51 PM
specops1526's Avatar
specops1526
Beluga '97 90
Driving the 90 today and I constantly hear "clank, clank" from the front end. Definitely louder when I hit some bumps on the road. Can almost feel it in the steering wheel too. Just wondering what I should look for before I get under the truck and start yanking on things? Maybe the steering stabilizer?
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old March 28th, 2010, 08:57 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Did you check the shock towers? Is the steering and handling off?
MUDSUX
Old March 28th, 2010, 09:04 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The answer lies within the question Grasshopper.
Old March 28th, 2010, 09:22 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
I was thinking shock towers.... but how would that happen in the driveway???
Old March 28th, 2010, 09:34 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
If one of the bushings degraded over time and just fell apart you would get this kind of noise.
Old March 28th, 2010, 09:46 PM
does it stop when you hit the brakes?
Old March 28th, 2010, 11:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
I had that when I lost the bottom bolt to one of my shocks
Old March 29th, 2010, 02:29 AM
specops1526
Beluga '97 90
It's only when driving especially going over bumps. I checked the shock towers and everything seems to be a-ok. All nuts and bolts present. The Pitman Arm Ball Joint seems to tilt back and forth. When I push the arm back, it hits the rod behind it making a noise. I'm hoping that's what it is. Everything else I pulled on seemed tight but I'm not sure that's enough force to reproduce the noise.
My shocks are original so that could also be the issue. I'm sure they need replacing due to age.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old March 29th, 2010, 09:31 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
If your shocks are original then the bushings are likely as toasted as the shocks and as Andrew said are a likely culprit. I would replace them right away, I'd say you got your moneys worth after 15 years.
Old March 29th, 2010, 10:45 AM
specops1526
Beluga '97 90
Yeah, you're probably right. Guess I'll be ordering this week.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old March 29th, 2010, 11:13 AM
bjf's Avatar
bjf
barry f
94 ST #395
I would be shocked if the bushings are done. Brian I dot think people realize your truck has only 45k miles.
Old March 29th, 2010, 11:27 AM
specops1526
Beluga '97 90
Hmmm, well I know the shocks are done. So maybe I should just start there. The Ball joint does have play in it like I stated above. I can't see anything else that would be rattling and clanking.
I've also had a vibration in the driver's front fender well when going about 30-40 mph. It's only for a few seconds but it's been doing it for the last 11 years and I've never been able to figure it out...
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Front End Shimmy loykd Defender Technical Discussions 27 April 11th, 2006 11:08 PM
Front End Shimmy bbandit Defender Technical Discussions 19 April 11th, 2006 11:06 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Front End Wobble RyanS Defender Technical Discussions 7 April 13th, 2004 05:21 PM
