Clanking/Clicking Diagnosis - Defender Source
Old July 24th, 2012, 10:55 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Just picked up a '94 RRC and it has TT lockers front and rear. I am usually an ARB guy, so mechanical locker noise is new to me. When I turn hard left, there is a slight binding and clanking noise, almost like a bad CV. Do the TTs make noise whilst hard turning?
When I turn hard right, there is no bind and no noise.
Semper Fi!
Old July 24th, 2012, 11:21 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Does it have Detriot Lockers or Truetracs (which are LSDs, not lockers)?
Old July 24th, 2012, 11:31 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I have TT both frt and rear and I have none of those noises that I am aware of
Old July 24th, 2012, 11:33 AM
Just my 2 cents but TC beats a trutrac to death. Why the PO went that direction is a mystery to me.
Old July 24th, 2012, 11:34 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Whats "TC"?
Transfercase?
Old July 24th, 2012, 11:48 AM
Wolf Fabrication
Sterling Archer
'08 D3
Trutracks, BW transfer case.
Semper Fi!
Old July 24th, 2012, 11:58 AM
Wolf Fabrication
Sterling Archer
'08 D3
Semper Fi!
Old July 24th, 2012, 12:17 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
I've had GBR-built TruTracks on my D90 for about six years now and they don't make any discernable noise. The only somewhat noticable thing about them is the front one has a (agreeable) self-centering quality after turning that others have also noted about the design.
Sorry, J. I don't believe the clicking/clanking would come from a TT unless there was something wrong with it.
Murph
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old July 24th, 2012, 12:18 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Truetracks shouldnt make noise. My Detroit makes a light racheting type noise when turning hard but truetrac in the front is silent.
Is the noise front or rear?
Old July 24th, 2012, 12:36 PM
Wolf Fabrication
Sterling Archer
'08 D3
These are GBR TruTracks. Okay, sounds like it's a CV. I'll pull it out (the CV that is) tomorrow and see.
Semper Fi!
Old July 24th, 2012, 12:57 PM
Probably a CV, but the VC in the t-case is going bad.
Old July 24th, 2012, 02:09 PM
Wolf Fabrication
Sterling Archer
'08 D3
Thanks.
Semper Fi!
Old July 24th, 2012, 04:25 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Sounds like you have the same problems with GBR 3rd's that I'm having.
Truetracs front and rear with 4.11 gears... watch the video. Audio is included.
" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">
Old July 24th, 2012, 07:54 PM
Check the swivel fluid, somehow I ran mine empty for an unknown amount of mile. It seem fine at this point.
Im not sure how I feel about that borg Warner, I know a few folks that have wheeled the pis out of them. The dirt time I took my truck out the CC was shot.
Congrats on the classic, bring it to uwharrie in the fall.
Old July 24th, 2012, 08:20 PM
Wolf Fabrication
Sterling Archer
'08 D3
Replaced the left CV today with a spare, still makes the noise. I'll tackle the right side tomorrow. It makes the noise on full left lock going forward, and full right lock going in reverse.
Semper Fi!
Old July 25th, 2012, 06:04 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
....and although it prolly has nothing to do with your noise, make sure the BW has ATF in it and not gear oil. Seems like that happens a lot and they (BW) do not like it.
Matt Browne
Old July 25th, 2012, 06:11 AM
Wolf Fabrication
Sterling Archer
'08 D3
Thanks, I am running through all the fluids today too.
Semper Fi!
Old July 25th, 2012, 06:58 AM
Wolf Fabrication
Sterling Archer
'08 D3
It's the right CV and stub axle. The CV is dry and the roller bearing in the stub axle is toast.
Isn't the RRC stub the same for D90/D1/RRC?
Semper Fi!
Old July 25th, 2012, 08:00 AM
If its a 94 probably sp, I think there were some that were 10 spline.
Old July 25th, 2012, 08:09 AM
I have a couple of the roller bearings, but they're at the barn. Pretty easy to replace. Knock it out from the outside with a long screwdriver that you don't mind whacking with a hammer. The bronze bush should be OK.
Unless it's got a lot of play and is pitted or otherwise worn, the CV should be OK with new grease.
Diagnosis help from the experts-HELP! jsimpson Defender Technical Discussions 2 February 25th, 2012 01:09 PM
Clutch Diagnosis dfscott Defender Technical Discussions 4 September 5th, 2011 09:35 PM
Trail break diagnosis phoenix37 Defender Technical Discussions 15 July 27th, 2009 02:41 PM
OBD2 - P0420 Diagnosis pcscharfe Defender Technical Discussions 1 January 12th, 2008 02:28 PM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
