"Clank" sound from back end - Defender Source
Old September 6th, 2013, 03:41 PM
graham's Avatar
graham
Graham Prentice
1996/Defender 110
Question "Clank" sound from back end
I have a 1996 Defender 300TDI 110.
I have developed a "Clank" sound from the back end. The sound only shows up after about 15min of driving and seems to be mostly from the right rear, although sound travels funny from a noisy truck.
The sound doesn't seem to happen around corners, but happens in a straight line and a steady or constant speed. The sound does not seem to happen during take off or acceleration but rather with constant load and often when decelerating.
The rear brakes are new, within the last few days, but this noise has been happening for a number of weeks.
I have not done a grease or lube on any rear bearings or fittings.
Any thoughts or ideas?
Graham
gprentice@trebnet.com
Graham Prentice
"an agent that works"
Old September 8th, 2013, 08:19 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
The first thing - for safety - is to check all the bushings/bolt/nuts in your suspension setup. Trailing arms, A-arm etc.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old September 10th, 2013, 12:12 AM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
check the propshaft UJ. the wear and make a clonc sound to.
ac
Sound Deadening Success... OCD90 Defender Technical Discussions 32 November 10th, 2012 09:44 PM
Tie rod end - metric or inch? byrdseye Defender Technical Discussions 3 October 1st, 2009 06:57 PM
The end is near Buckon37s Truck Build-up's & Restores 157 January 10th, 2005 06:16 PM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Back Door Rattle mdmccallum Defender Technical Discussions 7 December 19th, 2003 12:55 PM
