Cigarette Lighter adapter - Defender Source
Old October 20th, 2003, 02:04 AM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
Exclamation Cigarette Lighter adapter
Does anyone know anything about an adapter for the Defender cigarette lighter? I can't use anything in my lighter...the fit is too loose on the sides.
Thanks-
Old October 20th, 2003, 05:42 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
http://www.defendersource.com/discus...tml?1064798555
Chris von C
[/size]
Old October 25th, 2003, 08:13 PM
Platinum992's Avatar
Platinum992
Steele Williams
NAS Defender 90
my advice would be to go somewhere like pep boys and get a cigerate "outlet" that hooks up to your battery. If you have a 94 or 95' defender all you have to do is hook the adapter up to your battery (which is right under the seat) and you are set. This should also give you more power for laptops etc. Another suggestion is to go with a "power inverter" from walmart or other auto place (35-50) dollars and then you can plug regular a regular "ac" applaince in. This way you wouldnt need a speacial power source for your laptop, and you could plug your home charger into the inverter.
Old October 25th, 2003, 09:14 PM
Carefull with those power inverters. They put out an ugly 60Hz waveform and somethings don't like it.
Old October 18th, 2007, 03:22 PM
themaxx's Avatar
themaxx
Ade
94 ST
Originally Posted by chrisvonc
My Disco came with a little plastic ring adapter that I fit on my plug and then can put it into the lighter to make it fit right in there.
Our 94 D90 lighter does not have that problem.
CVC
Anyone know the part number?
Old October 18th, 2007, 03:54 PM
If you put in a seperate outlet, don't forget to put in a fuse.
Old October 18th, 2007, 03:55 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
As an option...
I was frustrated only having one 12v receptacle - so I just installed a couple of these this week .
West Marine has them instock.
http://www.marinco.com/scpt/ProdPage...20Recreational
Old October 18th, 2007, 03:58 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I don't remember my '96 Discovery lighter having this, and it fit fine, but I bought the truck used, so who knows. I did purchase a Hella Map Light that plugs into the cigarette lighter, and it came with a plastic adapter ring that I used for many different cigarette lighter power plugs int he Defender, until I lost it. And it is a nice map light to have as well..
~Scott T.
'95 D-90 ST - AA Yellow
Old October 18th, 2007, 06:38 PM
themaxx's Avatar
themaxx
Ade
94 ST
Yep yep, I just had the lack luster wiring job redone on my truck. Between the winch, lights, after-market stereo, ARB lockers...it wasn't pretty. So hopefully I won't blow as many fuses.
Originally Posted by pmd
As an option...
Where did you stall the others? Any pics?
Awesome, I need to get a hold of Grover, I was planning on buying his other map light.
Old October 18th, 2007, 07:33 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Not to Hijack, but I have been wanting to install a couple in the center depression where 90s have the clock and hazzard etc. switches. I want to have a black aluminum plate made to fit that depression that can hold the lighters and anything else I choose. I could buy a piece of aluminum and drill and cut and smooth etc. but is there someone with access to a CNC or that knows somewhere I could send specs and have one made inexpensively? I don't want to spend a fortune and it will be an incredibly simple design, but I am a bit of a perfectionist and don't want to stare at one every day where the radii aren't just right.
Old October 18th, 2007, 07:45 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I think I spent all of thirty minutes making one last month. The piece holding the clock and hazard switch makes a good template. The covering falls off . One problem is you have to cut the dash where the piece fits and glue the dash covering back in place. Also the hazard switch has to be hooked up to the wiring harness for the vehicle to function.
Old October 18th, 2007, 07:58 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
It makes a great template if you have one! I hadn't thought of that, but maybe someone remove it & has no use for it anymore?!? If anyone was just going to throw one out I'd be happy to pay shipping for it? Condition really doesn't matter as long as I can trace it.
I am not sure I follow about having to glue the covering back in place.
Fortunately my hazzard switch is already located elsewhere since I have a 110. All I have there is a depression and from the back the metal is cut to accept the clock etc. but from the front it is just solid vinyl.
Old October 18th, 2007, 11:52 PM
61rover's Avatar
61rover
John Crouse
Cigarette Lighter Adapter
Previous owner put one inside the cubby box. It's remarkably handy there.
Old October 19th, 2007, 09:47 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I went to radio shack and bought a new cigarette lighter outlet and it plugged right in. Nothing fits awkard in it anymore. Plus it came with a fuse.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old October 19th, 2007, 11:18 AM
pmd's Avatar
pmd
Paul Dandini
None :-(
[QUOTE=themaxx]Where did you stall the others? Any pics? QUOTE]
I know, I know I drilled into the center console - but I wanted easy access..
Here's what I did:
Old October 19th, 2007, 12:16 PM
themaxx's Avatar
themaxx
Ade
94 ST
Andrew, I believe either JimC and/or LenB might have already done something similiar.
The cubby, duh...that's a great location!
Here's what I did:
Thanks for the pic! Dispite the 'unholy' drilling, it looks really good!
Old October 19th, 2007, 01:26 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I don't mind tracing one and making a pdf file with dimensions if that would help. Can't do it until Sunday if you want it.
Old October 19th, 2007, 05:41 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
View of mine.
ht
cigarette lighter plug jjstahl3 Wanted 0 December 7th, 2009 09:21 PM
Wanted Cigarette Lighter Wolf Fabrication Wanted 14 January 8th, 2008 05:57 PM
Cigar Lighter Wiring m.michaels Defender Technical Discussions 5 May 31st, 2005 09:58 PM
Steering Wheel Adapter thelandroverguy Defender Technical Discussions 19 May 8th, 2005 07:16 PM
another momo hub adapter question dnewman9 Defender Technical Discussions 0 October 3rd, 2004 08:46 PM
