Cigar Lighter Wiring - Defender Source
Old May 31st, 2005, 01:01 PM
m.michaels
Matthew Michaels
1997 D90 SW
Does anyone know which wires go where on the Cigar Lighter? 97 SW if it makes a difference.
I guessed at it once, and killed a cell phone and the fuse . . .
My wife for some reason thinks the truck should not be in a constant state of disrepair . . .
I think of it as continuous improvement . . .
Thanks!!
Old May 31st, 2005, 01:04 PM
LOL! Do you have a volt meter, the polarity may just be backward on the wiring to the plug.
Old May 31st, 2005, 04:46 PM
m.michaels
Matthew Michaels
1997 D90 SW
How about makin' it easy for me - what color wires to what post . . .
If reversed polarity means blown fuse and fried cell phone I get it, but what that means for putting it back together it doesn't help . . .
Or if you can tell me how I would check that? It seems like alot of the male baldes on the cigar ligther fit alot of the wires (i.e. only one of them is smaller for a smaller wire)
Thanks a bunch . . .
Old May 31st, 2005, 06:27 PM
I cant remember right off hand exactly what the back looks like - but the orange wire goes to the light if you have one, the green wire (switched power) connects to the "center" post and the black (ground) wire connects to the remaining post. If that information fries another cel phone charger, then I was wrong.
If you have a pic that will help - Its just been too long since I installed my lighters.
Old May 31st, 2005, 09:21 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
I believe that the furthest away contact (that hits the 'nose' of the lighter element) is the positive one. The sleeve is the ground. Can anyone confirm?
DW
Old May 31st, 2005, 09:58 PM
m.michaels
Matthew Michaels
1997 D90 SW
I can confirm . . .
The red and white wire (or orange) goes to the light, black goes to the blade on the rim, and green and orange goes to the center post. Of course colors probably vary from Defender to Defender
I think the first time I ended up with the ground in the middle and the power to the outer rim . . .
Thanks for the help guys, now on to the next trinket.
ht, wiring
Cigarette Lighter adapter boshea Defender Technical Discussions 17 October 19th, 2007 05:41 PM
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
The Summer Cigar P.I.F. Eric Siepmann Misc. Chit-Chat 0 June 1st, 2005 02:26 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
