Cig lighter blowing my USB chargers - Defender Source
Old January 25th, 2014, 07:24 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Question Cig lighter blowing my USB chargers
Hi - anyone understand the cause of this? I tried three different USB chargers (for a wire going to iphone, etc to charge it) and the cig lighter blew all three of them out. They won't work with any other vehicle now, dead.
Cig lighter still works.
Old January 25th, 2014, 08:06 PM
Originally Posted by wicks View Post
Hi - anyone understand the cause of this? I tried three different USB chargers (for a wire going to iphone, etc to charge it) and the cig lighter blew all three of them out. They won't work with any other vehicle now, dead. Cig lighter still works.
Possible that the cig lighter is wired backwards and the USB chargers aren't protected against reverse voltage.
Old January 25th, 2014, 08:48 PM
wicks's Avatar
wicks
Wicks
That must be it! I should know - had the same problem on the extra cig install on the GSA.
Here are my other two instruments/electrical problems:
- Flashers go in fast mode. When hazard switch on, that is the normal pace of flashing.
- Instrument lights are dead - speedo, etc., and the clock and things around it. Except for cig lighter. Every other green light is dead.
Old January 26th, 2014, 11:11 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I made the same mistake in my ROW 90; figured red and black were fairly universal, or I assumed green was ground... Whatever it was my steering column started smoking after I installed a new 12v socket; I tore it out while I was driving lol
Old January 26th, 2014, 11:59 AM
People please learn to use a test light ... Connect one end to the truck body ... Touch the other end on the wire to be tested. If it lights up its hot otherwise it's switched off, fuse blown or ground.
Not so tricky!
Old January 26th, 2014, 12:05 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Not so tricky!
Where's the fun in that...next you'll want everyone to use a meter...where does it all end!
Old January 26th, 2014, 01:51 PM
wicks's Avatar
wicks
Wicks
do use test light - but have to remember the outer part of the cig lighter should not be the hot part.
any thoughts on the other two problems?
Old January 26th, 2014, 02:51 PM
rover gauge ... diagnosis not guess work ... universal healthcare and liberals driving defenders!
Ma get me my goddam gun!
Old January 28th, 2014, 02:27 PM
wicks's Avatar
wicks
Wicks
Diagnosis not providing results, possibly due to my lower skill levels on electrical issues...
So bumping these two questions:
- Flashers go in fast mode. When hazard switched on, that is at the normal pace of flashing.
- Instrument lights are dead - speedo, etc., and the clock and things around it. Except for cig lighter. Every other green light is dead after this cigarette lighter incident. Did I blow all of them out maybe during this cig lighter fiasco?
Old January 28th, 2014, 03:13 PM
YOU need to troubleshoot it.... First check the fuses.... If those are okay, YOU need a wiring diagram and a meter and find the location of the problem. We can't fix you wiring issue over the computer.
Old January 28th, 2014, 03:17 PM
spoilsport!
Old January 28th, 2014, 03:45 PM
Breaking these out
Flashers:
In normal operation are they fast or slow?
In hazzard operation are they fast or slow?
Instrument lights dead? check the fuses
Old January 28th, 2014, 03:46 PM
Cigar lighter should have a green with orange tracer providing switched 12V+ via fuse 19. Ground is black. When dash lights are on a 1.2W lamp that gets power from fuse 12 on a red/orange wire and grounds thru the case to illuminate.
------ Follow up post added January 28th, 2014 03:49 PM ------
Suspect fuse 12. It provides power for all interior dash lamps.
Old January 28th, 2014, 09:08 PM
wicks's Avatar
wicks
Wicks
Normal operation of flashers = they are fast.
Hazard switched on = all 4 lights blink at the normal rate.
Old January 28th, 2014, 10:01 PM
Lights stock? Fast flashing is burnt out bulb or low wattage bulbs.
Old February 4th, 2014, 02:18 PM
wicks's Avatar
wicks
Wicks
Lights - I changed the front blinkers out for the euro piece, the smaller white ones.
Old February 4th, 2014, 04:03 PM
Prob wrong bulbs then.
Old February 4th, 2014, 04:30 PM
wicks's Avatar
wicks
Wicks
THANKS Bill, was fuse 12.
ht, wing
tapping into cig. lighter circuit doscazadores Defender Technical Discussions 10 October 30th, 2012 12:20 AM
which fuse for cig. lighter circuit doscazadores Defender Technical Discussions 0 October 23rd, 2012 11:17 PM
Clock / Cig Lighter / EMER Flasher Alum Plates Update SafariHP The Vendors Loft 0 May 18th, 2008 09:06 PM
Clock. Hazards, and Cig Lighter plate Joe P Wanted 2 August 31st, 2005 10:30 AM
Blowing Rock, NC WCURoverD90 Trips, Trails and Events 23 December 2nd, 2003 02:16 PM
