Choosing shocks/determining valving...??? - Defender Source
Old April 20th, 2006, 09:38 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Question Choosing shocks/determining valving...???
Virtual shopping time!
Thanks to a good friend (isuzurover,some may know him on other BBs)
I have the chance to get 4 shock absorbers from US,wider choice,
better prices,no issues with VAT,duties,fees,whatever,just the cost of the shocks.
Too good to say no...
So I could ride the wave and buy some blingy toys.
Good Keith suggested Bilsteins 7100s,but they're too $$$ for my budget...
Then I am considering these:
5150 series
Pros:
they come with reservoir which is not bulky,close to the body and can be set in any position (top)
they come at 99.50 USD from eshocks
they are available in 6.5" to 14" travel
Cons:
pin>eye adaptors are needed (can fab) but I like the idea,easier for maintenance...
2 choices of valving only: 255/70 or 170/60
never seen them fitted to a D90 (!)
As I don't have the slightest clue of whater this is a proper valving or not for my application...
...opinions are welcome.
The Cube is a DD.
Spring rate is 170 lbs./inch on every corner (17.71" for a roughly +2" lift)
Here I presume stiff shocks would compensate...but when "stiff" is too "stiff"???
Bolt-on goodies include the 8274 on custom bumper,sliders,and-assuming I'll ever find the way-Husky in the rear
Exo shock mountings from Keith...yum...or custom made...maybe...in a future...
I am just playing with some ideas...so,should I be completely wrong for some reason,feel free to:
-teach me (tell me why!)
-suggest alternative options (preferably cheap)
TIA!
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old April 20th, 2006, 10:50 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
You would be better served buying the 7100 non res. I have heard good things about Rancho=
Old April 20th, 2006, 10:57 AM
Cube II's Avatar
Cube II
Michele
1997 D90
I've heard of mountings failures on Ranchos...?
Michele
D90 VNTdi
[O]===[O]
Old April 20th, 2006, 11:12 AM
tron's Avatar
tron
Thomas F
Recently Roverless
Putting the Bilsteins on this weekend...I will let you know how it goes.
Old April 20th, 2006, 11:21 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Will those 5150's even work inside the spring? I could see them working on D2 upper towers but I think you would want to cut out a space in the tower so there would be room for the reservoir.
Chris von C
[/size]
Old April 20th, 2006, 11:30 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Post
5150s?
Chris,good point.
Custom made turrets would be on the list.
Modifying a DII turret is an option,
but I fear it could weaken it...
Michele
D90 VNTdi
[O]===[O]
Old April 20th, 2006, 11:41 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Originally Posted by Cube II
5150s?
Chris,good point.
What's wrong with the Orams???
John C.
Old April 20th, 2006, 11:45 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Erm...nothing I guess?
Michele
D90 VNTdi
[O]===[O]
Old April 20th, 2006, 12:03 PM
JohnC
Ok....
Just curious, you have better shocks over there why bother getting stuff from here....
Check out the ProComp shocks, they ROCK!!
John C.
Old April 20th, 2006, 03:27 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
These are pretty nice!
Name:	110 resto 008.jpg
Old April 20th, 2006, 03:40 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I just put ranchos 9000's on. Ill let you know how they are once the truck is together.
I talked to Steve at rovertyme(18046394180) and he recommended the shock with the correct travel.
Old April 20th, 2006, 03:54 PM
JohnC
I think you will find the Rancho 9000s a bit hard. Now if you are going from OMEs to Ranchos then I'm sure you will like them.
John C.
Old April 21st, 2006, 03:24 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Post
I know what you mean.
ORAP/ORAM may be better but they're $$$.
Procomps are relatively cheap,but choice is limited to 9000 only.
You can easily find the MX6s adjustable over there,just to say one...
In the end,I just like to try something different from what the 99% of the people use here.
Take axles for example...the local trend commands they have to be MD...
I went for RT axles...
It's just me...
Michele
D90 VNTdi
[O]===[O]
Old April 21st, 2006, 02:08 PM
Chris V
Guest
Posts: n/a
I brought Merv a set of Rancho RS9000X to Ireland a few years back they are 9 position adjustable, not sure how he liked them.
Old April 21st, 2006, 02:13 PM
Who made those? I need new shock towers for my Fox Shox.
Old April 21st, 2006, 03:15 PM
Cube II's Avatar
Cube II
Michele
1997 D90
ARGH!
Don't tell me about your Fox shocks!
Evil!
Gimme ideas!
Ranchos...uh...9014 (or '12?) as used with the DR kit at the time?
Procomp MX6s?
Anyone?
Michele
D90 VNTdi
[O]===[O]
Old April 21st, 2006, 03:31 PM
ARGH!
Evil!
Gimme ideas!
Procomp MX6s?
Anyone?
I won't tell you about them, or that I broke one of the remote resivor lines and I am driving around on ONE shock up front and it is doing fine all by itself! Sure it is a little bouncy but have you ever gone down the road with No shocks up front? I have, that is scary!
If you go Ranco be sure to get eye mounts and NOT the pin type that break (I broke 2 twice!) And if you go longer then stock you need to get external mounts otherwise you will bottom out the shocks inside the springs and they won't last very long!
vin
Valving Fox Shocks lynchee Defender Technical Discussions 0 November 18th, 2008 11:22 AM
Choosing a top vkv Defender Technical Discussions 27 March 5th, 2008 11:52 AM
Bilstein 7100 Valving ini88 Defender Technical Discussions 5 July 26th, 2007 01:29 PM
Fox Shocks Valving Buckon37s Defender Technical Discussions 1 May 25th, 2004 06:47 PM
