Chequer Plate - Defender Source
Old December 12th, 2010, 04:09 PM
Grover's Avatar
Grover
Chequer Plate
Think'n about putting chequer plate on the "D" but drilling holes into un-scathed panels makes my skin crawl . Has anybody used a less permanent solution? Possibly using and adhesive or silicon?
I don't want to do anything to my "D" that can't be undone...
Cheers...
Old December 12th, 2010, 05:21 PM
ORover and a few others have used silicone adhesive instead of screws or rivets
Old December 12th, 2010, 07:14 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
drill baby, drill...
- Charles Eames
Old December 12th, 2010, 07:29 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Just drill it! I just installed mine on my freshly painted rear tub. Did not hesitate.
Once you drill the first one you are committed an the others are easy.
Old December 12th, 2010, 10:16 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Drill. You can use rivet inserts if you would want them more easily removable.
Old December 14th, 2010, 08:05 PM
SeattleRRC's Avatar
SeattleRRC
Woody
1990 RRC SWB, 1994 D90 ST
Drill.
My hood chequer plate is on with rivnuts but it created a 'gap' btwn the chequer and the hood. The wingtop chequer is bolted straight in and fits tight. With engine heat, ambient heat, cold, snow, ice, I wouldn't chance silicon to hold the plate on my truck. Are you really ever going to take it off???
Old December 14th, 2010, 11:14 PM
Grover's Avatar
Grover
Thumbs up
Originally Posted by SeattleRRC View Post
Drill.
Will I ever take it off?...well odds are no...BUT I would hate to one day wakeup and regret drilling holes into it...I guess I just need to muster the stones and do it...
What thickness is the genuine LR 5-bar plate? RN sells 3mm thick Mammouth 5-bar.
Here is a photoshop of what mine would look like with anodized aluminum 5-bar...
Name:	my d with chequer plate.jpg
Old December 14th, 2010, 11:23 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Once it has been on there a while, its going to mess the paint up. If you wanted to remove it, you would need to repaint. Its easy to fill holes then.
And hay
And I love you too
Old December 15th, 2010, 02:33 AM
specops1526's Avatar
specops1526
Beluga '97 90
Your truck looks too clean to ruin the panels with some decorations that require drilling. I'd leave the truck as is if I were you...but to each his own. Drilling can't be undone and you can only have original paint once.
Also, I believe silicone based adhesives will ruin automotive paint. I think urethane based is what you need to use. Double sided tape may even be better. That's what they usually use to adhere side mouldings to vehicles.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old December 15th, 2010, 07:35 PM
maleger
Marc-Andre Leger
3m
There is some 3M adhesive sheet stuff that is used for carbon fibre panels. It's supposed to be very strong. However i don<t know where you can find it... because I would buy some !
Old December 15th, 2010, 07:44 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Sure drilling can be undone.
And hay
And I love you too
Old December 15th, 2010, 08:01 PM
specops1526
Beluga '97 90
not without some body filler...which then means you have to repaint but I'm guessing once these things are on you've committed and aren't going to remove them anyway.
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old December 15th, 2010, 09:02 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
puddle wielding?
Old December 15th, 2010, 09:07 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Originally Posted by airbornrover View Post
puddle wielding?
I can weld.
And hay
And I love you too
Chequer plate panels? turbodave Defender Technical Discussions 4 October 30th, 2008 08:53 PM
Wing Top Chequer Plate Frankie Carbone Wanted 4 September 20th, 2007 05:53 PM
Iso Rear Door Chequer Plate willtillery Wanted 2 April 10th, 2005 02:11 PM
2mm 5 bar chequer plate mattdh Wanted 1 August 6th, 2004 05:46 PM
5 Bar Chequer Plate Supplier bd90 Defender Technical Discussions 9 January 7th, 2004 10:19 PM
