Checking the LT230 Breather - Defender Source
Old December 12th, 2010, 08:56 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
My D-90's Transfer case has always leaked. It not too bad...more of a seeping. I know that this is pretty standard for the LT230 but the smell of gear oil makes me nuts.
I've had the seals replaced and it has helped a little but it still leaks. I really can't tell where it's coming from other than I see the oil on the bolts at the bottom of the case.
I'd like to check the breather to make sure it's not clogged and adding to my leaks by building up too much pressure in the case.
What the best way to do this?
I'm hoping that I can do this from under the D-90 as I really don't want to have to pull my Tuffy console and access plate under it.
Any suggestions or tips?
Thanks!
-Tim
Old December 12th, 2010, 11:48 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Pulling the center panel in the seat box definitely gives you the best view. (see attachment) Might as well upgrade the all the breathers too...
http://www.lucky8llc.com/Products.asp?ProductID=4147
lt230
New style breather tube!! 48vphantom Defender Technical Discussions 1 August 7th, 2005 09:05 PM
Lt230 Refit Nil Defender Technical Discussions 5 December 2nd, 2004 12:36 PM
LT230 needing rebuild Abrooks For Sale - Parts 15 October 4th, 2004 10:14 AM
Lt230 & Lt95 tbmcneill Defender Technical Discussions 4 February 21st, 2004 04:23 AM
Spell checking now available chrisvonc Support & Suggestions 4 November 24th, 2003 11:33 AM
