checking main bearings on a 3.9 - Defender Source
Old June 18th, 2015, 07:56 PM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
I been battling low oil pressure for a while now. I ordered a new oil pump gear housing, and while it gets here, I was told to check the gap on the main bearings...sometimes you can loose pressure that way? I have the oil pan out. But im not sure which gap im meassuring. Should I remove one of the bearings? Also, I feel a little play on the timing chain. Not much, but I can move back and forth a little. Is this normal? Rover has 145, 000 miles. Head gasket was done. But no work on the bottom half to my knowledge.
Thanks.
-Gabe.
Old June 18th, 2015, 08:37 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Not sure if the Dro will chime in, but he just sanded the housing. Look at the oil pump gears and check if the housing is marked/scared. I don't think I would worry much about the main bearings this early on.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old June 18th, 2015, 08:41 PM
My timing chain was stretched at 117k so imagine yours would be a canidatecandidate for replacement .
Old June 18th, 2015, 10:15 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
is the engine making noise? how low is the pressure ?
you can check the rod to journal clearance with Plastigauge - Plastic Precision Clearance Gauges
but if your loosing pressure from excessive bearing clearance most likely your looking at a rebuild
normally you can get away with squaring up the oil pump end plate and a set of gears and stretching the spring
No Mall crawler here
Old June 19th, 2015, 07:38 PM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
I got the gear housing out. There seems to be wear on the flat face against the gear. Also, what is the correct clearance between the gears? Ill put some pics up...
4.6 Crank/Pistons, 3.9L and Main Bearings Method PHX For Sale - Parts 3 February 12th, 2015 02:37 PM
Wheel Bearings and stub bearings Naplm00 Defender Technical Discussions 9 March 11th, 2011 10:17 PM
Checking the LT230 Breather timtimtj Defender Technical Discussions 1 December 12th, 2010 11:48 PM
Checking codes on '94 D90 cellulararrest Defender Technical Discussions 7 August 28th, 2006 05:23 PM
Spell checking now available chrisvonc Support & Suggestions 4 November 24th, 2003 11:33 AM
