Checking codes on '94 D90 - Defender Source
Old August 24th, 2006, 11:11 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Hey guys,
My check engine light has been coming on at random times. When I shut the truck off and start it up again it goes away and all is well. The only thing I have noticed is that sometimes the idle dips quite low after starting when warm, but it comes right back up to normal. Other than that it has been running great. I would just like to know what's tripping the light.
I read on here that there is a display underneath the passenger seat, but I have been unable to locate one. Am I missing it? I found what all the fault codes mean from robisonservice.com, so I'm all set there.
Thanks in advance!
Old August 24th, 2006, 11:42 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
On a 94 NAS D90 the code display is in the RH footwell (behind the AC if you have factory AC).
Email:
Old August 24th, 2006, 11:48 AM
cellulararrest
Chris Snyder
Thanks Mike. There is a panel there that looks like it can be removed with a few screws. I assume that's it? You don't mean literally behind the A/C do you? That would be a pain.
Old August 24th, 2006, 03:40 PM
ECR's Avatar
ECR
Yup, behind the AC and depending on the mood of the guy who instaleld the AC back in 1994 it could be easy to get or hard to get.
If you look at the bottom of the AC duct (the pastci part that holds the vents) that runs side to side in the car you'll see little plugs (or holes if the plugs are gone already). Remove the plugs and the AC vents and you can get the screws that hold the upper duct to the lower dash and that gets the AC duct out of the way. This will expose the top of the AC system and hopefully the code reader and the diagnostic plug.
This is for the factroy 1994 AC system only. The later replacement systems are very different.
Email:
Old August 24th, 2006, 07:34 PM
cellulararrest
Chris Snyder
Alright great. Took a look. It doesn't look too difficult. I just have another question though. Since the check engine light only comes on randomly (I couldn't get it to come on driving around today), will the code be stored even if the light isn't on? I don't want to take all that off then have no code there.
I appreciate you taking the time to answer this for me. It's what makes this place great!
Old August 26th, 2006, 07:18 AM
btate
Bryan Tate
d90
I believe the code reader only displays when the Check engine light is on....
At least that's what mine seems to do.
You can turn the key to accessory position and look for larger red numbers on the bottom of the display. You will not miss them if the check engine light is on
Old August 26th, 2006, 10:35 AM
cellulararrest
Chris Snyder
Ok thanks. That seems to be how it's behaving. Now I just need to get the check engine light to come on.
Old August 28th, 2006, 05:23 PM
cellulararrest
Chris Snyder
Ok I've got something strange going on. The check engine light finally came on, but I got nothing on the display. Let me just make sure that I'm looking at the right display. I've attached a photo to this post.
Thanks again for your time guys.
90, d90
94, AA Yellow D90 Zimbo76 For Sale - Vehicles 9 October 27th, 2004 10:39 AM
Stock 94 D90 Parts For Sale Joe B For Sale - Parts 1 January 14th, 2004 01:52 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
Is it a 94 or 95 D90? PT94D90 Misc. Chit-Chat 5 November 12th, 2003 01:17 PM
