Checking center diff end float - Defender Source
Old June 16th, 2016, 01:53 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
So I'm aware that Land Rover isn't known for making tightest, most noise free drivetrains but I think it's become excessive on my truck and I'd like to dive into the T-case and see what I can find. It really clunks loud when I let out the clutch or change gears and when it's parked in gear I'm getting about a 1/4 rotation of the driveshafts before it locks up so I think it's time to start looking, so I was curious if I could check end float with the box installed. For the center diff, can I check the float with the intermediate gear installed or does that all have to come out? Lastly, can I check movement on the input gear with it installed on the transmission? I've never opened one of these up before but I've been watching videos so.. I willing to at least take a look.
Old June 17th, 2016, 07:07 AM
Naplm00
Matthew
Probably not end float issues, most likely worn input/output shaft splines or shaft collar bearing. This is a very common problem
Old June 18th, 2016, 07:27 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Loosing the washers inside the LT230 generally will cause some more issues!
Old June 18th, 2016, 07:38 PM
Remove the PTO cover and then rotate the output shaft back and forth to look at input spline wear.
Old June 19th, 2016, 07:46 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
On the bench mine looked fine. No apparent gear wear or excessive lashing but in the truck there is some play when shifting. Over time I find you adapt to minimize the affects by timing your
Shifts and playing with rpms. Sucks but just another little character traits we love to hate sometimes.
Old June 19th, 2016, 03:30 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Been all over the Brit, Aussie, and ZA forums dealing with a clunk in my driveline.
Adjusting your shift or "live with it" are not the correct answers, according to those forums.
Properly toleranced and adjusted t-case, gearbox, clutch, and diffs will make the difference.
KGH - Defender Snob
Old June 19th, 2016, 03:40 PM
1of40's Avatar
1of40
1of40
Originally Posted by KGH View Post
Been all over the Brit, Aussie, and ZA forums dealing with a clunk in my driveline. Adjusting your shift or "live with it" are not the correct answers, according to those forums. Properly toleranced and adjusted t-case, gearbox, clutch, and diffs will make the difference.
That's helpful.
LT230: What's better? Proper end-float or preload torque? TheOneTen Defender Technical Discussions 11 July 2nd, 2015 06:16 PM
Sticky gas level float on NAS110 Neil McCauley Defender Technical Discussions 0 April 23rd, 2014 03:56 PM
Checking the LT230 Breather timtimtj Defender Technical Discussions 1 December 12th, 2010 11:48 PM
Checking codes on '94 D90 cellulararrest Defender Technical Discussions 7 August 28th, 2006 05:23 PM
Spell checking now available chrisvonc Support & Suggestions 4 November 24th, 2003 11:33 AM
