Check your trans filter! {manual} - Defender Source
Old May 24th, 2004, 08:48 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I know this was posted a little while ago BUT check your trans filter! The coating on the inside of my trans had clogged my filter soo bad I had a hard time removing it!
Old May 25th, 2004, 09:51 AM
Remind me on the location of the filter?
Old May 25th, 2004, 09:54 AM
I couldnt find mine either?
Old May 25th, 2004, 10:23 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
It is under the trans extension case> Look for the the finger!! It is a 15/16 bolt remove bolt and if the filter does not come out with the bolt them stick you finger in the hole { I know what your thinking } & pull it's about 2 inches long.
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
My pic didn't work!
Old May 25th, 2004, 10:32 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Pic by mister Hand!
manual
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
How difficult is it to convert auto trans to manual in a D90? jaherring Defender Technical Discussions 14 June 17th, 2004 02:05 PM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
where to find rebuild manual for 4.0L? Chris Cox Defender Technical Discussions 0 January 27th, 2004 09:36 PM
trans filter change question J4hand Defender Technical Discussions 0 December 17th, 2003 11:58 AM
