Check your chassis/bulkhead bolts! - Defender Source
Old February 22nd, 2008, 01:10 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I discovered this week that one of the bolts that secures my bulkhead to the chassis outrigger behind the front wheels had lost its nut and was about to fall out. The other side was missing its bolt entirely! Well, this explains the creaking that I heard every time I turned a corner. I was able to source some new bolts, nuts, and washers from the local CAT dealer, cost about $10 total. Getting the bolts back in was kind of a bitch. When the floor jack and a 2x4 failed to position the bulkhead properly, I put a large pry bar on the outrigger, using the bulkhead as the fulcrum. This shifted the bulkhead sufficiently to get the new bolts through.
Just an FYI. Check your bolts. I have no idea how mine came so loose but I'm guessing that my truck is not the only one with this problem.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old February 22nd, 2008, 03:24 AM
NashvilleRedD90's Avatar
NashvilleRedD90
Will Peters
'97 NAS D90 ST #1704 -4.6
When I had to replace those to put on my sliders they were not real easy to get out. I think both broke when I tried to get the nut off (impact wrench) so then I had to use an impact hammer to get them out...
Also there are supposed to be shims in there between the bulkhead and outrigger...
'97 D90 - 4.6
'00 D2
Old July 12th, 2012, 03:02 PM
maleger
Marc-Andre Leger
Can anyone confirm the part number on the bulkhead bolt ?
When removing the original NAS running board / step / rock magnet, one broke off and needs to be replaced ASAP. I think the correct part is MRC9420 which it seems was superseded by AYG500080. It would be a M12 x 180 metric bolt.
Old July 12th, 2012, 03:24 PM
maleger
Marc-Andre Leger
Sorry, with more research I found this thread with all the answers: http://www.defendersource.com/forum/...ead.php?t=3736
Old July 12th, 2012, 05:47 PM
Slather them in anti-seize before installing. Shafts, heads and nuts.
Old July 12th, 2012, 09:14 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I completely agree
Land Rover 110
Old July 13th, 2012, 07:57 AM
maleger
Marc-Andre Leger
I'll do that
Excellent advice, I'll do that.
Old July 13th, 2012, 08:57 AM
Originally Posted by JSBriggs
You east coast guys can disregard this. Your bulkhead bolts are fused to the bulkhead at this point and will never come out.
-Jeff
Rust has its benefits!
bolts
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
Head Bolts. Sealant? or no sealant? Hans Defender Technical Discussions 1 January 19th, 2005 11:42 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
