check fuel pressure 94D90 - Defender Source
Old July 30th, 2014, 11:47 AM
wesley0620
Wesley Everett
1994 Defender 90
Does anyone have the part number for the tool you use to install inline to check fuel pressure on a 94D90?
Old July 30th, 2014, 12:36 PM
Don't 94s have the schrader valve on the fuel rail to check fuel pressure there? 1995s aren't as lucky.
Old July 30th, 2014, 12:58 PM
1995 has the valve.
Old July 30th, 2014, 01:00 PM
Originally Posted by rover4x4 View Post
1995 has the valve.
I wish. It must be a SW thing - mine doesn't have one.
Old July 31st, 2014, 09:50 AM
wesley0620
Wesley Everett
1994 Defender 90
No Schrader valve on my 94 but the I found the adapter it is OTC 7665
Old July 31st, 2014, 10:13 AM
Grover's Avatar
Grover
Mine doesn't have the valve either...
Old July 31st, 2014, 12:08 PM
pendy's Avatar
pendy
jim pendleton
89'd90
93, 94 and 95 do not have the valve. The 4.0 in a 97 does have a valve.
There is also an adapter that fits in the engine bay for diagnostics. If you search way back there will be part numbers and sources to buy that tool.
legend in my own mind
Old July 31st, 2014, 12:17 PM
There's a thread somewhere around here with the part # you need...let me find it.
------ Follow up post added July 31st, 2014 12:19 PM ------
Bingo, look at post #11 - I picked one of the OTC7665 up (I want to say I ordered it through Advance Auto), and you just put it in place of the fuel filter and you can tap a gauge into it no problem:
http://www.defendersource.com/forum/...+pressure+test
90, d90, fuel
Fuel pump fuse? 94D90 wesley0620 Defender Technical Discussions 0 June 9th, 2014 12:32 PM
Fuel pressure check red&yellowrovers Defender Technical Discussions 4 August 22nd, 2012 08:45 PM
How to check fuel pressure? Heath Defender Technical Discussions 3 January 11th, 2005 02:28 PM
FS: 94D90 ST with cedar strip removable hard top bigpalley For Sale - Vehicles 11 May 7th, 2004 01:27 AM
Squeeking/Chirping belt - 94D90 Glenn_Guinto Defender Technical Discussions 4 April 2nd, 2004 01:24 PM
