Check for Rust *Bulkhead... - Defender Source
Old October 21st, 2009, 01:04 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Is there a simple way to check the bulkhead for rust?
Weldon
Old October 21st, 2009, 01:07 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
This project shows where they commonly rust:
http://www.eastcoastrover.com/219.html
Look in those areas to see if you find rust on the subject truck.
If you pick up the floor mats and see a lot of rust that means its pretty far gone.
Email:
Old October 21st, 2009, 01:30 PM
They also rust at the top under the seal for the windscreen.
Old October 21st, 2009, 02:00 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Last Sunday when I changed my vent seals, I noticed some paint bubbling slight rust along the base of the exterior screen after I took off the vents. I sanded them down and used touch up paint. Just an area to look at.
Robert Deniro
Old October 21st, 2009, 03:45 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Guys,
I really appreciate the guidance here. Just found some rust within the rear crossmember & within the battery box. The chassis other than what's on the crossmember looks good. As for the battery box, now has a hole just under the battery from me cleaning it out. Rest of the box looks fine. Yeeesss I changed the direction of the battery so it will not drop through. So far from what I can see the bulkhead should be fine. Under the mats no rust present and the seams on the floorboard appear to be good. I will check the other areas you guys listed. Thanks again for the help!!!
Weldon
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
Check Engine light jracenstein Defender Technical Discussions 14 February 22nd, 2005 05:32 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
