Check Enginge light and Gas Cap - Defender Source
Old November 30th, 2007, 01:50 AM
floyd650's Avatar
floyd650
Alex Lapidus
1994 D90 ST #1716
I was loading my new D-90 on a ferry in Alaska and they wouldn't let me take the full Jerry can of gas on board with truck. So I hastily whipped the gas cap off and dumped 1/2 the gas in the tank and 1/2 the gas on the side of the truck because the spout sucked. At any rate immediately after that the Check Engine light came on. I have taken the cap on and off a few times, but the light remains on. The cap itself is one of those with the little spring-loaded door in the center of the cap that allows you to fuel right through the cap without taking it off, but I took it off anyway in the above episode.
1. What is going on and what should I do?
2. The Parking Brake light came on with the Check Engine light and when I looked in the repair manual it looks like they are on the same circuit - Does this explain why they are both on?
Thanks in advance for any help!
PS: If I disconnect and reconnect the battery will it reset the check engine light?
Old November 30th, 2007, 02:05 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
What is the year of your truck? The easiest is to read the code to know why the light is on. Then you can fix the problem and reset the light.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old November 30th, 2007, 02:32 AM
floyd650's Avatar
floyd650
Alex Lapidus
1994 D90 ST #1716
It is a 1994.
Old November 30th, 2007, 02:55 AM
MonLand
Loic Fabro
Originally Posted by floyd650
It is a 1994.
Then read the code on the LED display thingy. If you're not sure where the display is located, do a search either on this groups or go to the TECH or FAQ section of the d-90 source web site. I think this is somewhere in the passenger foot wheel area (on the '95, it's under the passenger seat).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old November 30th, 2007, 06:05 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Then to reset, disconnect the battery and then reconnect.
Old November 30th, 2007, 08:49 AM
MonLand
Loic Fabro
If you fix the fault, the light will go away after 3 engine cycles (warm-up, cool down).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old November 30th, 2007, 11:16 AM
Welcome to Land Rover ownership!
On my '94 it's in front of the passengers right knee (under the dash). You have to crouch down to see the code (with the ignition on).
To reset the codes, you can disconnect the ECU (to the right of the passengers right foot). Turn the ignition on, wait for the check engine line to go off. Turn off and reconnect the ecu, then start it.
hth
charles
Old November 30th, 2007, 05:08 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Is there a code readout on the NAS 110s? If so, where is it? I have had absolutely everything out and have not seen it...but I haven't looked for it either.
Old November 30th, 2007, 06:38 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Thought is was passenger side behind A/C - similar to 94 defender.
Old November 30th, 2007, 07:19 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Well, on the 110 there is no A/C there but I'll take a look when I get back to the truck.
Thanks!
Old December 2nd, 2007, 11:16 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
It's there Andrew. Passenger footwell under the ECU. You have to pull it off of it's mount in order to read it (the LED display faces away from teh passenger).
Chance
Old December 2nd, 2007, 11:19 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Hmmm...Typical Land Rover convenience!
Old December 26th, 2007, 04:27 PM
floyd650's Avatar
floyd650
Alex Lapidus
1994 D90 ST #1716
Just a belated update: The code claimed that my idle was out of whack and when I referenced the repair manual, it outlined a complex procedure that involved snipping some hose and doing a slew of other random things... I finally unplugged the battery, waited 30 seconds, and then reconnected it. This entirely fixed the check engine light and the code has stayed off for several weeks. I guess the little read-out deal is not that accurate. Still perplexed by what set it off in the first place...
Old December 27th, 2007, 05:44 AM
MonLand
Loic Fabro
And you won't know until you run those tests! ;-)
More seriously, some electrical issues are very hard to troubleshoot because they come and go. You could have a connector that does not like to be wet and raises errors when it is (like some plug somewhere in the airbag system of my '96 Disco) or you could have a connector going bad that randomly stop letting the juice through (like the three feet connector between the chassis and the fuel pump) or it could also be a dirty sensor (or a sensor going out) or .....
Good luck with the troubleshooting!
MonLand
1995 D90 NAS
1996 Discovery NAS
gas, gas cap, ht
Weird brake light issue on my 97 Please HELP! Cyborg Defender Technical Discussions 8 July 12th, 2009 01:04 PM
help with brake light defender1844 Smaller Projects 2 February 20th, 2008 10:28 AM
Oil Light Flickering/Oil Pump Glenn_Guinto Defender Technical Discussions 13 October 27th, 2004 08:27 AM
